Home > Maintenance & Mods (L405) > UK L405 SDV8 Right Hand Turbo Replacement
PHG
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Hi I'm about to set out and replace the variable turbo on the right. Research shows step 1 is remove engine. Does anyone have any tips or knowledge if the replacement can be done from underneath without removing the engine? Google is a bit light on info. 2015 SDV8 AB
2008 TDV8 Vogue gone
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #677257 4th Nov 2023 6:28pm
PHG
Any information would be appreciated if you know of any successful DIY right side turbo change. Cheers, 2015 SDV8 AB
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #677361 5th Nov 2023 8:41pm
i put 'turbo replacement' into our search and it came up with these threads...should be some thing that will help you,
https://www.fullfatrr.com/forum/search.php...rch_time=0 ... - .- -.
Post #677364 5th Nov 2023 9:09pm
PHG
Hi Stan thank you very much for the reply and help, loads of info on L322, I'll look through the wiki too. 2015 SDV8 AB
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #677370 5th Nov 2023 9:49pm
Daveyp
Hi, I’m also looking for tips on the primary right hand turbo replacement for L494 2015 SDV8, possible without removing the engine? Did you manage this @PHG?
Post #688190 16th Mar 2024 9:23am
kevinp
Interested to know why you are having to change the turbo.
Post #688191 16th Mar 2024 9:29am
PHG
Hi, sorry I thought I’d reported back.
I did not change the primary in the end but it does look do able with engine in.
My turbo was misdiagnosed by experts as needing replacement.
If your car pulls ok with no smoke when codes are cleared there is a good chance you just need an actuator which it very hard to get but very easy to fit.
I used turbo vanes in the midlands but ended up doing the whole job twice due to poor QC.
Cost about £250 for the rebuilt part.
Cheers Peter. 2015 SDV8 AB
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #688192 16th Mar 2024 9:35am
Daveyp
Thanks both for the replies,
Car is 2015 SDv8 L494 and has a noise under low rpm acceleration. Around the 1250 mark it makes a whirring noise which you can hear from the cabin. I suspect the right hand turbo, and only under load as reving car on the driveway doesn’t produce the same noise. I’ve performed a smoke leak test on the air intake side and that didn’t highlight any pipes leaking boost.
Laying under the car I can see the actuator move but I might need to do a bit more research checking it today. The car pulls ok, no smoke and no codes. Just this weird, ghost like whirring noise
Post #688194 16th Mar 2024 10:16am
PHG
Mines a l405 so no experience of turbo access on l494.
Your whistle could be a turbo required or could be an air leak.
Maybe worth a webuyanycar type solution if no warranty available.
Cheers, Peter. 2015 SDV8 AB
2005 TD6 Vogue gone
2003 TD6 Vogue gone
Post #688195 16th Mar 2024 10:30am
Daveyp
Thanks for getting back to me PHG. I’ll get it properly diagnosed and report back here for anyone in the future.
Post #688196 16th Mar 2024 10:38am
iainvr4
2004 Range Rover Vogue Td6 Java Black
Hi, did you ever get the primary turbo off? I’m about to try and get mine off so looking for tips esp the top water pipe bolt.
Post #717592 7th May 2025 9:28pm
