Home > Technical (L460) > Dash predicted range of 51 miles at 100% charge
Worried_well
I've just purchased an ex-demonstrator P460e with 9000 miles showing, and I was alarmed when the predicted range showed 51 miles after fully charging it. I was expecting to see a prediction of 75 miles and get less. Can anyone tell me what their P460e dash range prediction is at 100%.
Post #717189 1st May 2025 6:03am
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
That’s about right. My predicted range is anywhere between 51-58 miles when fully charged.
It varies with external temperature, driving style etc. L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #717190 1st May 2025 6:51am
Pixelpower
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
Mine always says 50, but that seems about right. Only filled it up twice since I had it though, so that works for me.
Post #717602 8th May 2025 7:58am
Kot
Re: Dash predicted range of 51 miles at 100% charge
Dont worry, it will soon start showing less than 51 miles Whistle 2018 SE SDV8 4.4 Byron Blue
Post #717603 8th May 2025 9:35am
AndyS
My 440e shows anything between 53 and up to 60 miles, I thought the 460 had a greater range. Current fleet:
2020 McLaren 600LT Spider
2020 Mercedes C300 Cabriolet (sold)
2023 L460 PHEV 440 SE
2021 Toyota GR Yaris
1992 Lotus Esprit turbo
2019 Alpine A110 (French rubbish now gone)
Post #717625 8th May 2025 9:42pm
JackRegan
Like your average MGP and range readings, they reflect your recent driving style and usage.
Use your battery when it's cold, dark and drive the car spiritedly, will return a lower estimated range from a full charge. Now that the warmer weather is here, you may see this figure creep up over the next few weeks, depending on your usage.
I tend not to take too much notice, charging the car most evenings if I've used the car that day.
It helps that I'm on Intelligent Octopus at 7p per kWh, meaning a full charge from empty is only around £2.65. 2024 P550e Autobiography
2016MY TDV6 Autobiography
2011MY 5.0 SC Autobiography Black
2005 TD6 Vogue
Post #717637 9th May 2025 7:21am
Yousif
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
It also tends to show a higher range after being used in hybrid mode as it is recovering some charge along the way in that mode and it seems to take an average from recent driving . On my 440e I can see as high as 62miles but I would say the real range is 50-55 miles depending on weather and driving style as has been mentioned.
Post #717654 9th May 2025 2:30pm
AnnualMan
Switzerland
Mine pretty consistently displays 55-56 miles or range. Given the battery size that makes it a fair bit less efficient than my previous L405 P400e 2025 P550e AB
Post #717888 13th May 2025 4:13pm
jamesey
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
My P550e also shows 50miles….but as I am running it in driving very slowly…I would expect nearer the 70 mark… maybe it is all the massage seats and air con that is stopping getting anywhere near the claimed 73 miles. The 50 miles is accurate which I suppose is a benefit. Has anyone signed up for octopus intelligence?
Post #718761 29th May 2025 9:08am
