Home > Group Buys > L405 Jack Pad
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I’m interested 👍
Post #694472 15th Jun 2024 10:28am
TomekW
Poland 2019 Range Rover Autobiography 5.0 SC V8 Indus Silver
me too
Post #694489 15th Jun 2024 2:03pm
ttrw2
And me
Post #694508 15th Jun 2024 7:37pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
You can just buy rubber adapters off EBAY for just a few quid, why go to the trouble of making stuff.
I use these with the steps out https://www.ebay.co.uk/itm/335415250744?it...R9KowNeDZA
Or just Hockey Puck with the steps in, nothing fancy https://www.ebay.co.uk/itm/125550837575?it...BM2vfg14Nk
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #694513 15th Jun 2024 9:00pm
Gremlin500
I’m resurrecting this thread, as there was no real solution found for the L405.
Did anyone investigate further as to the possibility of a round aluminium puck with slot/screw/dowel pin to replace the Weber “Cow Horns”? Hopefully, we can moooove along and make some progress.
(Notice what I did there? Rolling with laughter Rolling with laughter )
One caveat might be the 26.5cm closed height of the Weber/ Sprinter bottle jack, (measuring to the end of the piston) I didn’t measure the L405’s clearance to the F/R jacking points in extended mode yet, has anyone checked that? Confused V6 Vogue - “Less is More” - less to go wrong!
Post #717644 9th May 2025 9:15am
Gremlin500
Thinking out-of-the-box
I’ve come up with a novel adaptation to the BMW Mini jack adaptor for the Sprinter jack:
Milled a 17mm x 10mm slot into the round puck, and a 16mm x 15mmm deep hole in the rectangular block a-la “upside down” Laughing Just got to drill the 4mm hole for the roll pin halfway up the hole.
I’ll let all know how it goes…… V6 Vogue - “Less is More” - less to go wrong!
Post #718188 19th May 2025 8:58pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I'll be interested to see how your findings.
If all goes well will you be making some? Whistle
Post #718221 20th May 2025 1:02pm
