Home > Maintenance & Mods (L322) > Well this isn't great...
Floopy
I need to have the timing chains and tensioners replaced on my 06 4.2 S/C as at least one primary chain has stretched, it's covered just shy of 260k so I suppose it's expected.
Initially I thought it was just the S/C coupling however on closer inspection the rattle seemed to be affecting only the left back so I removed the cam cover last night and have confirmed that the timing chain's etc. are shot. I've attached a video showing the extent of play.
Sadly I have neither the free time, nor the tools to DIY it. 2006 L322 Vogue SE 4.2 S/C (no longer owned)
2008 L322 Vogue SE 4.2 S/C
Post #717690 10th May 2025 11:46am
Unfortunately at 260K I would say the cost of repair would be well in excess of the fattys worth... Sad Pete
-Click here for Thread-
Post #717700 10th May 2025 3:06pm
Floopy
In pure monetary worth, quite possibly.
However, in every other regard it's been pretty faultless and the cost of selling it and replacing with another (pre-tax hike) 4.2 S/C would be greater than the cost of just repairing the devil I know. 2006 L322 Vogue SE 4.2 S/C (no longer owned)
Post #717707 10th May 2025 3:43pm
Fair comment... hope it's not too much... Thumbs Up Pete
Post #717714 10th May 2025 6:34pm
DrRob
Give the folks at Glenrands a call. Tell them I sent you Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #717723 10th May 2025 8:45pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I’m with floopy on maintenance economics
A properly sorted L322 is worth more than book value
And with an 06 reg….depreciation doesn’t come into the economics
The economics are annual servicing/ fuel / maintenance / VED items to drive an 06 like a newer car costing 10s of thousands
Post #717744 11th May 2025 9:33am
