Home > Maintenance & Mods (L405) > Lowering the subframe slightly - propshaft off ?
fisha
So looking at the logistics of doing the ACE pipework. Haylands took the full subframe off ( here ) whilst in this video, the subframe was partly lowered and hanging from the unwound bolts.
This latter method i think suit me better in terms of trying to fit the pipes, but if I was doing that, would I have remove the propshaft ? Or would there be enough play if I undid the centre support bearing ?
Just trying to plan it all out in advance at the moment. V8 or else ...
Post #698776 24th Aug 2024 2:58pm
I would think there is enough room for the prop to drop some amount, if it's enough to change the pipes, that's a suck it and see job... Thumbs Up Pete
Post #698783 24th Aug 2024 6:31pm
Mikey
If you can't remove it from the rear diff, remove it from the transfer box end and drop the shaft with the subframe/diff assy Thumbs Up
Post #698784 24th Aug 2024 6:54pm
fisha
Thanks chaps, like you say, I’ll just wing it. V8 or else ...
Post #698813 25th Aug 2024 3:12pm
fisha
So, I’ve reached the point of : you can undo the subframe bolts and re thread them back in a few turns, and drop the subframe to hang on them without having to remove the prop. You do need to undo the middle bearing support though
My clean and tidy garage setup … no lifts here!
Tomorrows job is to see if this enough space to feed the pipes through:
 V8 or else ...
Post #699277 1st Sep 2024 9:45pm
If it isn't then take out the nearside bolts and drop it on a jack a bit more that side, just be careful and don't catch anything... Thumbs Up Pete
Post #699281 1st Sep 2024 9:56pm
fisha
Oh, good idea. V8 or else ...
Post #699288 1st Sep 2024 11:39pm
fisha
Just to feed back, this worked and worked very well. New rear ace pipes installed and rear coolant cross over coolant metal pipes now replaced with a single run of hose.
When it’s all done, I’ll do a different thread with some observations of doing the ace pipe job on the ground without a lift. V8 or else ...
Post #699595 6th Sep 2024 9:30am
Top job, should be sorted for a few years now... Thumbs Up Pete
Post #699618 6th Sep 2024 1:17pm
NoHandSignals
United States 2016 Range Rover 5.0 SC V8 Aruba
Did my rear ACE pipes With the fuel tank in position and by only dropping the rear subframe a couple of inches, leaving it hanging on a few threads like you did. I did this with the car on a ramp though!
Absolutely no way I could figure out or handle doing it with the car on the floor. Well done! Shocked
Post #699742 8th Sep 2024 3:54am
fisha
Edited to add a link to the thread which talks about doing the pipes yourself for anyone reading these threads in the future:
https://www.fullfatrr.com/forum/topic71213.html V8 or else ...
Post #716117 14th Apr 2025 10:23pm
Jordi R
United Kingdom 2010 Range Rover Supercharged 5.0 SC V8 Santorini Black
Range Rover Sport 2010 Supercharged rear ACE leaking
Dear all,
I own a Range Rover Sport 2010 Supercharged 5.0 V8 since 2022 (I am the 3rd owner).
I bought the car with a slight leak on the rear ACE Bar but I haven’t had any issues with it so far… (Touch wood…! Smile)
I am keen to keep the vehicle as I just love it. It’s used as a weekends car and once a year we drive to Spain and back.
I have brought the car to a Range Rover specialist in Kent recommended by a good friend of mine that is mechanic.
They advised that some of the parts to replace the rear ACE bar are back ordered from Range Rover without an ETA for those… Therefore they said that once the rear ACE bar goes that gets vehicles
out of the road unfortunately…
They also advised that pipes are highly corroded and they were unsure if new pipes will easily go in… They also mentioned that as per their previous experience Valve block might also have to be replace and if you got that far and half of the car it’s dismantled you might as well check front ACE bar and pipes and replace them at the same time… So the job gets bigger and bigger…
The car also was diagnosed with the below issues on it’s last health check carried out by the same Range Rover Specialist on December 2024 which I am also keen to get resolved apart from the AC leak which I think I could live without it in the UK.
Drive Shaft Boots (CV, if Required)
NSF outer cv boot split- we may not be able to release the driveshaft from the hub and this repair could end needing complete driveshafts and hubs
Suspension (damage/Leaks/etc)
OSF Drop link boot split
Rear ACE bar is leaking and pipes are very corroded pipes- they may not release from the bar itself and then would require replacement and valve blocks-
However if more work is needed we cannot get the parts as they are back ordered
Front anti roll bar bushes have some play in- suspect noise from right hand side as no play in any wheel bearings-
Misc
Propshaft bearing is split
Would recommend a deglaze and clean up for the brake pads squeaking as plenty left on them- hard to tell what brand they are however as its worn off- so could be a cheaper material and clean up may not be long term
No undertrays were on the vehicle- just a note
Engine
Vacuum valve on the front of engine is leaking oil quite heavily
I am looking for some advice and help to try and resolve this issue please…
@Haylands, I have seen some amazing restoration and replacement works for ACE pipes that you have posted previously… Would you please be able to assist?
Many thanks,
Jordi
Post #717807 12th May 2025 2:13pm
Try the "Sport" forum, this one is for the full size "proper" Range Rover....
https://www.rrsport.co.uk/forum/ Pete
Post #717835 12th May 2025 9:06pm
Jordi R
Yes sorry. Thumbs Up
Post #717838 12th May 2025 9:26pm
Jordi R
Thanks Pete.
Post #717839 12th May 2025 9:26pm
