Home > Maintenance & Mods (L405) > 2017 L405 4.4 SDV8 front left drive shaft stripped
woodyrvf750
Has anyone else experienced a front driveshaft where the thread in the fixing nut has been stripped?
According to Land Rover Sytner Coventry mine has this issue which is causing this problem a clonk when pulling away because the nut can't be torqued up correctly. It also can not be undone..
There's nothing in the service record that suggests the drive shaft has ever been removed.
?si=dJyTQ0Zna7JezXht
Post #717829 12th May 2025 8:07pm
JamboM3
I have not experienced this issue, if it helps, but have had to replace the N/S Drive shaft on my MY17 SDV8 and I’m pretty sure the other side is not long for this world
Post #717836 12th May 2025 9:16pm
Mikey
Yes, if the old nut has been reused, they tend to damage the threads during refitting, or if they nut has been used to pull the shaft back into the hub
New nut should be used every time
Post #717845 13th May 2025 6:20am
woodyrvf750
Thanks both. Is there likely to be damage to the opposite, "female" groves in the hub if the drive shaft has been constantly moving back and forward?
Post #717876 13th May 2025 1:51pm
