Home > Technical (L405) > SDV8 strange HP fuel pump noise
Astanavits
France
Hello everyone
I have a 2014 SDV8
the other day when opening the hood while the engine was running I noticed a strange noise coming from the CP4 injection pump, like a timing chain tensioner noise but it comes from the injection pump everyone knows that these pumps are fragile the noise is really audible when the rpm drops back to 1000 rpm
I checked the entire fuel system:
-pump relay R18 in the trunk
-the fuel sender in the fuel tank (stage 1)
-the lift pump (stage 2) under the engine ECU i have LHD.
-replaced the fuel filter twice
-common rail pressure regulator left
-common rail pressure sensor right
-Camshaft Position sensor
-Crankshaft position Sensor
-FCV fuel volume control valve on the top of the pump
-PCM update with lastest version available
I found several testimonies from owners who changed the injection pump 800£ because this noise but the noise is still present after replacement
I also discovered that if you disconnect the FCV valve on top of the pump when the engine is at idle the noise disappears immediately
disconnecting this valve brings the pump to its maximum operating pressure, I don't understand why the noise disappears at high pressure, does anyone have any ideas?
I'm going to post a video of the noise, can the owners of TDV8/SDV8 4.4L tell me if it's normal? or if I'm paranoid?
Post #712102 18th Feb 2025 3:15am
Astanavits
France
Another exemple
Post #712107 18th Feb 2025 3:57am
Astanavits
France
Another one
Post #712108 18th Feb 2025 3:58am
Astanavits
France
Even a 2019 MY ??????? Listen at 0:59 ???? im not mad 😂
Post #712112 18th Feb 2025 5:31am
Astanavits
France
Update: Today I received and installed the stage 2 pump bosch 0986580131 / LR023043
problem not solved but the new pump seems to build up pressure faster and I can no longer hear the pump from inside the vehicle ,Obviously the pump is in poor condition, there was black fuel in the pump, I imagine that the pump in the tank must be in the same condition
next the in tank fuel pump
Post #714145 15th Mar 2025 10:03pm
Astanavits
France
Hi everyone, I received the new in tank fuel pump today and installed it, quick work, really easy unfortunately the sound is still present it has diminished but it is still present
Post #715941 11th Apr 2025 10:07am
Astanavits
France
Update: today i open the high presssure fuel pump to see if i found any scratch or wear on the roller or the plunger hopefully the pump is in perfect condition
Post #715942 11th Apr 2025 10:07am
the plot thickens....
its frustrating when you cant find an obvious solution... ... - .- -.
Post #715943 11th Apr 2025 11:11am
Astanavits
France
Exactly, I think the problem is not mechanical but software.
Post #715949 11th Apr 2025 12:24pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
I’ve heard a lot of SDV8’s make this noise, mine does but yours does seem to have it bad, have you tried premium fuel, my own SDV8 does run better quieter on premium fuel.
Post #715955 11th Apr 2025 1:00pm
Astanavits
France
I've tried everything diesel cleaner, Total Excellium (premium diesel), nothing seems to work.
Dave, what year is your car?
Post #715960 11th Apr 2025 2:06pm
diesel Dave
My current one is 2020, previous 2015 and both make this noise but more intermittent than yours sounds. It kind of comes in when full pressure is reached or that’s what’s it sounds like, then goes away, I work for a local indie where we work on lots of these and they all do it in varying degrees so I’ve put it down to a characteristic of the engine. But I do think premium fuel helps mine. Hope you get to the bottom of it.
Post #715967 11th Apr 2025 4:45pm
Astanavits
France
Hi everyone, quick update, I finally found out where this noise comes from.
After several hours of research with on the road with SDD to reproduce several driving situations, I discovered that the noise appears under certain deceleration conditions. When the noise appears, the PCM commands the fuel rail to 1000 bar, then after another deceleration to 600 bar, then to another 300 bar, etc., etc.
It is a function of the PCM called (ZFC) zero fuel calibration:
when you release the throttle pedal and the vehicle is pushing the engine (ie. coasting down a hill), the ECU can sense this and proceeds to shut the fuel off to the injectors.
Then, one at a time, it fires the injectors and begins to increase the pulse width signal to each injector until the ECU sees measurable changes at the crank sensor and backs it off, proceeding to the next injector.
This allows the engine to constantly re-learn the zero fuel pulse width point for each injector, optimizing mileage & minimizing emissions as the injector and engine components gradually wear.
as precaution, I replaced the camshaft position sensor and the crankshaft position sensor because over time I found several owners of 4.4 TDV8 who encountered no start problem or rough idle problems, so at this level I am safe for a long time.
So I tested the 8 injectors to check their resistance. They are supposed to be between 150,000 and 210,000 ohms.
My 8 injectors are between 177,000 and 180,000 ohm.
So the electronic part is ok, but I think the mechanical part of the injector is at the end of its life.
To finish, this damned noise comes from the fact that the PCM is trying to compensate for the wear of the injectors in vain, so the only solution is to replace the injectors
Post #717773 11th May 2025 8:03pm
knwatkins
Thank you for the excellent analysis and write up! Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #717847 13th May 2025 7:56am
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Do you have any other photos of the electrical connector for the fuel pump and the plastic mount that fits in to the floor of the passenger compartment?
Thanks.
Post #722320 4th Aug 2025 7:38pm
