Home > Technical (L405) > Warning lights on
Gronsh
Warning lights on
Garage did front left wheel bearing, now lots of light on dash emergency brake assist, abs, antiskid etc…
Help, also power steering is stiff! ...
Post #717848 13th May 2025 7:59am
Sounds very much like a faulty ABS sensor. Got - 2017 SDV8 Autobiography in Loire Blue
Post #717850 13th May 2025 8:16am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Have you checked the earth strap, anything weird like one of the headlights not working?
Post #717851 13th May 2025 8:16am
Kot
Have you a code reader and read the DTC's and then reset/erased them?
What DTC have you left after final read? 2018 SE SDV8 4.4 Byron Blue
Post #717874 13th May 2025 1:21pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Had the same thing on my l322 when I did the wheel bearing,I did replace the abs sensor but fault codes only cleared when I used a genuine Range Rover sensor
Post #717893 13th May 2025 8:12pm
