![]() | Home > Technical (L322) > 4.4 TDV8 - Restricted Performance + Charging System Error |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
If you go to 2000rpm, does it still say 11.5v?
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
+1 for alternator but I would check that the alternator is turning under full load, A mate recently changed a battery and alternator on a JLR car then found out it was a failed bottom pulley. I'm not sure if yours will have a damped pulley but it costs nowt to check. |
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 41 ![]() ![]() ![]() |
Working on a bit of a process of elimination here. First battery, then other items.
