I’ve done this job a few times and was well worth doing + not massively difficult.
A few pointers -
The seat base foam part will depend on the year and whether the seats are heated only or heated and cooled. The latter have an additional pad stuck to the base foam which includes ducting for the air from the peltier unit. If you have this type, I’d buy both parts as detaching it from the old foam base is tricky without destroying it, plus it’s usually deformed beyond use anyway.
I’d suggest speaking with Duckworth LR who will be able to confirm the exact foam parts you need for your model from your VIN and will usually offer a discount if you mention the forum. You’ll also need the replacement hog rings to attach the cover to the new foam (some have used zip ties but personally I’d use the proper hog rings).
Remove the seat from the car - it can be done in-situ but much more of a ball ache accessing everything and it’s pretty straightforward to remove if you take care manoeuvring it out.
Disconnect the battery (after adjusting the seat to remove the four large torx head mounting bolts) to avoid the airbag error light or don’t worry if you have an IID to reset it anyway.
Buy some decent metal snips & hog ring pliers - the leather cover is secured to wires moulded into the seat base foam with metal hog rings, these need to be cut off to remove and re-attached to pull the leather cover securely back onto the new foam.
If you’re methodical, it should take a morning or afternoon at most to do.
Any questions, please shout.
Jonathan Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
