Home > Technical (L405) > Some strange electronic gremlins
pasha0305
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
I’m wondering if anyone encountered this problem before:
Quite often I lose functionality of certain electronics in the car. Heated/cooled seats (front ones), heated steering wheel, the mobility of the seats, illumination of the driver’s side window switches, high beam assist, reversing camera (I only have the rear camera on my car) and the car doesn’t lock from the fob or at least it takes a good minute to recognise that I’ve pressed the lock/unlock button.
Now this is the funny part - this ONLY happens when someone is sitting in the front passenger seat! Of course they are not sitting in the seat when I try to lock the car but after we get out. My missus is very annoyed that I keep telling her that it’s “her seat” but I don’t get these issues when she is not in the car! (I already hear the jokes coming in haha!).
I will try and get under the seat and see if there are any bad connections but I am wondering if the hive mind on this forum has encountered something like this before?
The car is a MY16 TDV6. 2016 TDV6 Vogue SE Santorinin Black
Post #718331 22nd May 2025 12:08am
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
Haha! Dont have a wife so no, haven't seen that problem.
It could be a grounding issue. If you can, do a full code scan. There may be some codes that can help pinpoint the problem.
Short of that recommend checking these two items first.
1. Occupant Detection Sensor. Put a bag heavy enough to trigger the seat occupant sensor. Close all doors and see if you can reproduce the problem. If the problem shows up then remove the bag off the seat without opening any doors and see if the problem goes away.
2. If its not the occupant sensor then try the seat belt. Click it in place and see if you can reproduce the problem.
Post #718336 22nd May 2025 7:32am
ss10
Have a look at this also: https://static.nhtsa.gov/odi/tsbs/2015/SB-10105660-9340.pdf
Post #718337 22nd May 2025 7:39am
pasha0305
Thanks! Will try this first. 2016 TDV6 Vogue SE Santorinin Black
Post #718339 22nd May 2025 7:53am
pasha0305
Well…..some interesting developments. This morning the car wouldn’t unlock from the fob! Had to use the “secret” key. Of course the alarm went off and I could only get the car to start to the electronics on stage (before the engine starts) but no further. It also kept switching off pretty much immediately.
I called the AA and a chap came with a large battery charger, however upon inspection he said that the battery is fine!
I since have unattached the passenger seat from the interior and made sure all wires are ok there and indeed there was a wire which didn’t have its plastic grommet in the correct placeholder and was definitely snagging when the seat was moved all the way back (as the missus likes it).
Then I checked the earth in the wheel arches and the one in the driver side looked ok until I touched it and it fell off. I used a nearby nut to earth those wires but will drill a new hole and use a self tapper for security next week.
So in conclusion I can only thing that the snagged cable was somehow causing havoc with the BCM and perhaps the bad earth points were not helping. Will have a long drive tomorrow and hope it all works! Fingers crossed. 2016 TDV6 Vogue SE Santorinin Black
Post #718441 23rd May 2025 11:03pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Very interesting, as I encounter rather similar problems: https://www.fullfatrr.com/forum/topic73098.html
Post #718487 24th May 2025 3:54pm
pasha0305
Did you manage to get yours sorted?
Im only one day into what I think is my fix. Drive today for around 100 miles and so far no problems. However, it was only me in the car. Problems usually start when I have a passenger. So time will tell.... 2016 TDV6 Vogue SE Santorinin Black
Post #718490 24th May 2025 3:58pm
adara
Not yet—this is the worst kind of failure. The one that appears only occasionally and doesn’t trigger errors. The car works fine for days — or weeks, and then, suddenly, everything goes wrong. Steering column locks, refuses to unlock, screens starts rebooting, etc...
Post #718518 24th May 2025 10:06pm
Gremlin500
Body earths are a known and very common issue on the L405 as it ages, (I think there are 3 in total in both front wheelarches, but I can’t remember). Easy to get to. They can even visually look OK, then snap off if you try to loosen them or even just wire brush them to add some corrosion inhibitor. Before failing completely, they regularly can cause a myriad of simultaneous DTC’s anf faults. A weak battery can have quite similar effects, however, so check both.
If replacing, clean everything up REALLY well and smother with Lanogard grease or similar to keep the water out. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #718525 25th May 2025 12:04am
pasha0305
+1 on looking at earth points in the wheel arches. Mine snapped so I botched it.
I’ve attached the earth wired to another bolt just above the one that’s sheered off. However, I should drill a new hole and put a self tapping screw in there, but for now this will do.
So far no recent problems have reappeared. Fingers crossed.
Hope this will help. 2016 TDV6 Vogue SE Santorinin Black
Post #718526 25th May 2025 1:49am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
So, a list of annoying electrical gremlins I have encoured:
1. When selecting reverse, can't turn the volume down in the media
centre.
2. When it's wet ,I have to manually close the boot.
3. The heated steering wheel sometimes turns itself on.....
When it's already 30 degrees outside!
I'm inclined to think that the electronics/software were written in. the UK , which is why they don't work as they should!
Just an opinion.
Post #718537 25th May 2025 10:09am
adara
I checked the earth points on both sides. There’s only one wire attached to the right one and two to the left, both of them looking really good. I cleaned and tightened them anyway, even the three earth points under the bonnet on the right side.
Post #718590 26th May 2025 7:21am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
centre.
Just an opinion.
Error 1. I think is by default as in mine when in reverse the volume adjusts the parking sensor volume.
2. Whip the rear spoiler off, there's a bunch of earth's on the one hinge bracket that can corrode.
3. I had similar in my 2014 L494 with the heated wheel, whenever I visited a local Co op convenience store most times I got back in the car the heated wheel would be on, turned out the store had one of those high frequency kid scarer devices that omit a high frequency noise that only youngsters can hear, somehow interfered with the electronics. When they removed it (as it turned out they didn't have planning permission) the problem went away!!
Hope that helps!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718591 26th May 2025 8:09am
pasha0305
Getting closer to the root of the problem..... I hope!
After my last post everything worked well until the passenger seat was moved again. I have undone the seat and tilted it backwards to reveal the two little cutouts in the floor with electric wires coming out from it to the seat. Firstly I think there is a design flaw as the wires come out way too forward on the seat. So when it moves back, the wires get quite stretched! Then again, I'm not an engineer so....
Secondly I found that the fault which I have described above happens when the two little wires (red and black) seem to get tugged. I believe these wires are some 12v connection and when they get tugged but the other wires (as the seat moves) they lose connection for a split second but that sends a chain reaction to further modules (a but like one bulb not working on a chain of Christmas tree lights which means that the next lights will not work). This is all my theory so far, by the way! That wire does have a plastic grommet to keep it in place but it is not plugged in anywhere and I couldn't feel any place it could go, so I ended up gaffer taping it as far away from other cables as possible.
Had a drive in the car yesterday eve after the botch and all seems ok so far! If anyone with more seat wiring knowledge will back me up on this, that would be great! 2016 TDV6 Vogue SE Santorinin Black
Post #719456 9th Jun 2025 9:14am
