![]() | Home > Technical (L322) > 2011 4.4 TDV8 Road Noise |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 533 ![]() ![]() |
Are your Falcon's an All Terrain pattern? That would cause noise, but you most probably knew that already! |
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 34 ![]() ![]() |
Thanks Jon,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2695 ![]() ![]() |
I thought mine's noise must be the right front wheel bearing so had it replaced, but to no avail. The cause was eventually tracked to 2 brake lines vibrating together not far from the m/c due to a dislodged pipe separater. L405 D350 SE Carpathian Grey D5 19" rims |
Having spent a bit more time diagnosing I reckon its the left rear wheel bearing.
Looks like the entire assembly bearing included cannot be purchased online its either one or the other or both.
If it has an e-diff then jack both sides. L405 D350 SE Carpathian Grey D5 19" rims |
This would strongly indicate a wheel bearing issue to me. Checking for play (i.e grabbing the wheel top & botom) won't always find an issue, as you most likely already know! Your only choice may well be to change the bearing and see what happens. Having said that though, a set of 'chassis ears' may well be a good investment. They're pretty cheap on eBay / Amazon these days! Or just a plain & simple mechanics stethoscope might suffice to detect a worn wheel bearing. I have a similar issue with a Renault Master van right now, I've changed the same wheel bearing twice and still have noise issues, although I've noticed the tyre of the offending corner has worn unevenly, so I'm suspecting just plain & simple alignment in my case with this one! Might have to take my own advice and buy some chassis ears ! ![]() ![]() Jon Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Once a tyre has become noisy it won't ever be quiet even after the alignment is corrected. Move the wheel to another spot to see if the noise moves. L405 D350 SE Carpathian Grey D5 19" rims |
Thanks Graeme, I'll do that. Might even replace them. |
Thanks everyone.
