Home > My Range Rover > My 2012 Westminster TDV8
Page 5 of 5 <12345
Gsxr1250dave
I check my eBay there ok but still not the best I'm gonna get that phone holder my phone just falls off the magnet one
Post #711308 7th Feb 2025 11:42am
Gsxr1250dave
I bought these I'm sure the ones I got on a group buy on here years ago for my 2003 are brighter
https://www.ebay.co.uk/itm/273124852618?mk...media=COPY
Post #711329 7th Feb 2025 4:40pm
Gsxr1250dave
Deleted double post
Post #711330 7th Feb 2025 4:40pm
RobsterPC
Not much to report. The Most was due this week, it passed with zero advisories.
Next up, service next week. In the mean time it's developed a rattle from the drivers side at low speed. I think there's a loose heat shield that needs attention. I'll either get to it this weekend or I'll ask the garage to do it at the service.
Post #717948 14th May 2025 10:10pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
I have exactly the same rattle. My Indy has diagnosed it as the gearing on the high pressure fuel pump.
They say it’s very common and nothing to worry about you can get reconditioned Bosch pumps for approx £250-£300.
Post #717950 15th May 2025 6:51am
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
The rattle on mine is the DPF heat shield where all of the insulation has deteriorated. I need to either re-pack it or weld it in place so that it no longer rattles.
Post #717953 15th May 2025 8:37am
Steveg
I assume if it was the fuel pump you’d hear it on idle too.
Post #717954 15th May 2025 8:39am
toby1
I'd love to know from where as the lowest I've seen is £800-ish 2012 Vogue TDV8 in Aintree green over sand
Post #717961 15th May 2025 10:46am
JonnyCJ
I do hear it on idle. The high pressure fuel pumps are common to a lot of cars, albeit with slightly different part nrs and configurations.
Having had another look on eBay it seems I wasn't seeing the 4.4 TDV8 specifically, so pols for the incorrect pricing, which is much higher.
Post #717982 15th May 2025 4:01pm
RobsterPC
The RR is in for a service today. I asked them to look at the vibration when braking (warped front disks, nothing serious but will need fixing at some point), the slow coolant leak (another one) and the rattle.
The rattle is the slowly disintegrating exhaust heat shield. They're going to try welding it back up to see if that fixes it and if so for how long. About £100.
The expensive problem is the coolant leak. Apparently its the pipe from the resservoir down to the water pump (from their description, I may have misheard). This is apparently made of platinum judging by the cost of a new pipe. Another nearby pipe is leaking too. That one is only made of silver as its 1/3 the price of the other one.
The total including the service looks like its going to be £,1400. That's without replacing the warped disks, a legacy of my alpine trip back in January. They flagged up some mild corrosion underneath (no surprise there) but no other issues. Hopefully its back with me tomorrow.
Post #718674 27th May 2025 1:36pm
RobsterPC
Service report at 141,500 miles:
- Service completed, oil and pollen filter.
- Replaced pipework from coolant bottle to thermostat
- Top coolant hose replaced as it had previously been glued
- Welded up the heatshield
- Rear shock absorbers slightly weeping. To be monitored.
£1,493 spent. Hopefully things will quieten down now, both literally and figuratively, and I can have some steady, pain free and low cost motoring for the next year. Or is that hoping for too much given its a RR? :lol
Post #718766 29th May 2025 10:22am
JonnyCJ
The way I look at it is that I'd need to spend at least £600-£700 per month to get anything near as nice as an L322 on PCP, lease etc. That's say £7k per annum.
If I spend anywhere near half that on maintenance (which would be a heavy year), I'm still quids in AND get to drive a car I absolutely love, rather than a soulless box.
Spend the money and know you're adding value to your car and it will give you a good feeling every time you get your wallet out.
Post #718771 29th May 2025 11:11am
RobsterPC
Yup, it wasn't a whinge, it was a statement of fact that hopefully others will pay attention to when they look at that "cheap" FFRR. I agree, this is a great car to roll around in and I'd much rather put the cash into this than a lease payment.
Post #718786 29th May 2025 4:48pm
Page 5 of 5 <12345
