![]() | Home > Technical (L405) > 2017 FFRR Autobiography no dash |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1411 ![]() ![]() |
Check Battery and charge it.
TerryatHome Member Since: 17 Feb 2025 Location: Blackpool Posts: 7 ![]() ![]() ![]() |
Already scanned and any faults reset. Battery tested by Green Flag and battery ok. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3806 ![]() ![]() |
I had this on my previous RR, the dash display had failed and required replacement - the LR Warranty covered it, but it was expensive at the time from what the MD said. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
I did look at taking out the warranty but quite expensive. Kicking myself now it maybe a costly mistake.
I presume you have had the car for a while all working good then suddenly you get this fault? Or did you buy it like this?
Had the car about 4 months now with no problems until now.
Ah now we have the back ground |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 875 ![]() ![]() ![]() |
If it has a sliding roof this could be the problem...
Charliecloud Member Since: 03 Jan 2015 Location: Tonbridge Posts: 38 ![]() ![]() |
That looks like a great fix on the YT video.
Update, found this and it looked ok. However poured some water and then it pored down on the inside pillar.
