|  | Home > Maintenance & Mods (L322) > L322 air con pressure help |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349      | Yes , that was my understanding of the procedure, however if my gap tool is telling me there is 6.5 psi or bar then the compressor should be working so I’ll need to investigate that first then get a canister online since Halfords are not being very helpful! Thanks | ||
|  10th May 2018 7:00am |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349      | Yes dial right down and gap tool telling me the same , checked two fuses in passenger side under air conditioning but both ok , will have to do a search for the relay and further fuses for compressor , I would have thought that that pressure should energise it, what I don’t know is what side that reading is taken off , low or high? | ||
|  10th May 2018 8:09pm |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | red is high
|  10th May 2018 11:50pm |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349      | Yep I know , but if the diagnostic is taking the pressure reading off the high pressure line then , to me , the compressor should kick in when asked at 5.3 bar.
|  11th May 2018 6:51am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | 5.3bar, yes i wasn’t thinking about that, i don’t know what the high pressure side should read RR 2005 4.4 petrol
|  11th May 2018 9:46am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | Have you checked to see if you have power to the compressor, perhaps the clutch is not working RR 2005 4.4 petrol
|  11th May 2018 9:51am |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349      | Thanks for your reply , yes I know it’s not working , the clutch is not coming in, so when Iget home this pm I’ll further investigate, basically looking for power at the compressor terminal and or at the relay for it , do you know where the relay would be ? Cheers Pat | ||
|  11th May 2018 10:41am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | no, no idea RR 2005 4.4 petrol
|  11th May 2018 11:06am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | got this else ware, it was his fusebox
|  11th May 2018 11:34am |
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836      | Was looking at my gauges today, I don’t know but I think the high side should be about 150/160psi
|  13th May 2018 1:27pm |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 214      |
 Please do not try and put 7kg in !
|  29th May 2025 7:51pm |
| Posting Rules
