![]() | Home > Technical (L322) > Secondary Turbo Replacement - new question |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 292 ![]() ![]() |
£2,600 to me sounds as a bend-over and dry-hump price. Was he wearing a mask?
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 275 ![]() ![]() ![]() |
Have you done a smoke test ? the 4 rubber pipes (2 each side of the plenum) are notorious for causing restricted performance. A lot of peeps replace them with silicone. |
2012 MY will already have the latest silicone versions but it is a possibility. I am not sure the symptom is smell of oil as described though 2012 Vogue TDV8 in Aintree green over sand |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 200 ![]() ![]() ![]() |
I checked the 4 rubber hoses as they are either tge original ones or genuine replacements, all good.
And to be fair to the garage I checked on advanced factors website and tye quoted price is almost the same for a LR branded secondary turbo. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Autodoc is £1,257 plus £131.23 surcharge for the old unit (refundable on return). To confirm this is the left turbo?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
I’d get a second opinion for another good specialist as a double check |
Yes it's the left turbo as you look out from the drivers seat.
Following a read on here I had a look at the cross over valve that sits down below the radiator. I have the later non nut version.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
There's a turbo specialist in the midlands that claim they rebuild the turbos for Land Rover. A friend of mine spoke to them recently and they were under 700 quid to rebuild one and that came with a 2 year warranty.
