![]() | Home > Technical (L405) > L405 SDV8 intermittent starting problem |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 272 ![]() ![]() ![]() |
Could someone please confirm the locations of the various fuel pumps please as I’m unsure which one is the cause of my low fuel pressure? Thanks. |
niklasel Member Since: 08 Nov 2024 Location: Stockholm Posts: 12 ![]() ![]() ![]() |
Hi! There is one in the fuel tank accessible from the rear seat. The front one can be accessed from the engine bay to the left back. You need to remove the ECU as it is located under it. Cheers |
Ah, thanks.
I don't suppose you took any photos of the wiring beneath the seat for the fuel pump? I have a couple of unexplained connectors that I can't work out. They are from the same main loom and one does clip to the plastic fuel pump cover, but I don't think they are fuel pump related. |
