Home > Technical (L405) > headlights
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
headlights
hi my headlights are cracked so going to change them ,i have found a few but the last letters are different than what mine are (see photo) .anybody know if it makes any difference?
thanks will
Post #719152 4th Jun 2025 3:20pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
depends. AFAIK Last letter - revision - doesn't matter. Second from back must be the same
Post #719199 5th Jun 2025 2:48pm
will308f
Thumbs Up thanks , got my eye on a set and the numbers match so all good
thanks
Post #719200 5th Jun 2025 3:00pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
In some cases the last letter may make a difference as well.
On my car (2014 Autobiography) the difference between my headlight which broke and one from 2016 with same part number that I was trying to replace it with was the elimination of the aim adjustment motor. 2014 has it. 2016 doesn't. I suspect on the 2016 the beam cutoff is done by the high beam flap.
I transplanted the motor from the broken bits of my headlight into the used one I got from ebay.
Post #719239 5th Jun 2025 8:53pm
