Home > Technical (L405) > Fuel Pressure Issue
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Fuel Pressure Issue
Struggling to get my 4.4 SDV8 to start.
It turns over but doesn’t start. The only indication I have to go on is the fuel pressure reading below.
Does anyone have any recommendations for identifying which part of the system is the problem?
Thanks.
Post #718845 30th May 2025 3:16pm
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
That looks like the SDD screen. What all have you already checked?
Post #719241 5th Jun 2025 9:03pm
Mike Edwards
My SDD skills are limited at best.
There was an error code for camshaft position sensor so I checked the wiring and replaced the sensor.
The fuel pump beneath the ECU under the bonnet makes a high pitch whining noise but I’m unsure if that’s because it’s receiving nothing from the fuel tank pumps or if it is broken.
I’m also going to replace the fuel filter as I’ve no idea when it was last done.
Post #719257 6th Jun 2025 12:53am
toby1
It needs a minimum of 150 BAR to start and 300 to idle (I think). The pressure port at the filter has to be in the range 4-7 BAR.
I also have a cranking, non-starting car so I am watching with interest. 2012 Vogue TDV8 in Aintree green over sand
Post #719268 6th Jun 2025 9:22am
