![]() | Home > Maintenance & Mods (L405) > Put in 8.5 quarts oil exactly. Says overfilled? |
noone Member Since: 05 Apr 2025 Location: Florida Posts: 94 ![]() ![]() |
8 liters =8.454 quarts
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
If it’s easy enough todo, take out some and see if the message disappears. You’ll not affect the lubrication of the engine by taking 0.5 litre if it says over filled. V8 or else ... |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 285 ![]() ![]() |
Did you run the motor between checks? 2012 Vogue TDV8 in Aintree green over sand |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8749 ![]() ![]() ![]() |
Personally I like to keep the oil capacity slightly lower than full, it has so much oil in it because they want to keep the oil flowing when driving at silly steep angles, including side slopes. Anything over full and I'd suck some out, IMHO it will do more harm overfilled than slightly underfilled.... |
Checked again today, same exact spot, and it no longer says overfilled. At least I have a dipstick on the 2023 RR P400.
