Home > Technical (L405) > How to crank the 4.4tdv8 without starting
911r44
Hello
Can anyone suggest a method to crank the 4.4TDV8 but without actually starting it? I want to build oil pressure, not run the engine.
Thanks in advance
Post #715040 28th Mar 2025 11:29am
fisha
Disconnect the injectors ? ( assuming everything else is in place and running so to speak ) V8 or else ...
Post #715047 28th Mar 2025 12:44pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Remove the fuel pump relay.
Post #719635 11th Jun 2025 11:52pm
dhallworth
Unplug the crankshaft sensor so the ECU won't see the engine cranking over. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #719669 12th Jun 2025 7:13pm
