![]() | Home > Maintenance & Mods (L322) > Rear Shocks |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
I had no issues with Bilstein shocks on my MY12. The first pair of rears lasted as long as the orginals and another pair has just been fitted by the current owner.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 802 ![]() ![]() ![]() |
I just replaced my (MY12 CVD) rear shocks with new (OEM) Bilsteins from Island 4x4 @ £199+vat each. Perfect! The older I get, the more I realise that people confuse wrinkles for wisdom |
NOTSHARP Member Since: 04 May 2025 Location: Aberdeenshire Posts: 63 ![]() ![]() ![]() |
Many thanks to both of you.
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 202 ![]() ![]() ![]() |
Another vote for the Bilstein replacements from Island 4x4.
Thank you.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I too got mine from Island 4x4 a few years ago.
No answer to your current predicament as we only ever fit JLR parts, but just wanted to mention on the late model 322's all the rear shocks leak a little misting. Ive never Sean one that doesn't so... Note to later viewers of this post. Don't just change them as they look misty as they all do that |
Mine weren't misty, just worn-out. L405 D350 SE Carpathian Grey D5 19" rims |
Does this mean JLR parts only, or would you go with Bilstein rear shocks, or a GKN prop from normal trade sources? On the subject of the rear shocks, are they actually 'sided'? Different part numbers, but nothing to distinguish them out of the box. Fittings are the same and they turn 360deg, so I can't understand the two part numbers thing. I fitted them on a 'first out of the box' basis, so it's 50/50 if I'm wrong..... ![]() ![]() |
The bush extension on 1 side only that locks into the suspension arm determines to which side the shock will fit. L405 D350 SE Carpathian Grey D5 19" rims |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Do jlr make many of their own parts? 🤔 |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 714 ![]() ![]() ![]() |
LR only manufacture bodywork & assemble other suppliers parts Paul,
New shocks were fitted yesterday. The drive home from the garage is only a mile, but I noticed immediately that the clunk was absent.
