![]() | Home > Maintenance & Mods (L322) > Escaping coolant |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 233 ![]() ![]() ![]() |
Can you see any coolant in the "vee" of the engine, I have found coolant pooling at the back of the engine, in my case the multiple connector (LR005819) has split and is losing masses of coolant, a right |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
What engine ? .
3.6 TDV8, 86k miles, I must have dislodged something when I replaced the seals in the oil filter housing/fuel cooler/crank breather block. the plastic multi hose connector has split along the seam, can't see it but when squeezed with pliers there is fluid coning out of the seam. All the coolant was pooling at the back of the engine and running down the bell housing, the front was bone dry.
tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29 ![]() ![]() |
Mine is the 2011 TDV8 4.4 diesel. I can find no trace of any coolant anywhere, including in the V of the engine. I drove it back the other way for 4 hours last night after topping g up the coolant, and it is still full now after standing still for 24 hours, so I am wondering if it was just an air lock in the pipes from when I replaced the bottle? |
Howard Godolphin Member Since: 17 May 2025 Location: Holsworthy, Devon Posts: 1 ![]() ![]() ![]() |
When you replaced the header bottle, did you lose much coolant? It is possible that you introduced an air lock in the system and the recent drive has allowed that air to find the header tank. If there are no signs of a coolant leak, I'd be incined to top up the level correctly and then road test to get up to operating temperature then check level again. |
Thanks Howard, drove it home for four hours yesterday after topping up and did t lose any more coolant, so I am figuring it was the air lock. Fingers crossed! |
