![]() | Home > Maintenance & Mods (L405) > What’s happened here? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
Maybe cut away on the sills for deployable steps or similar which have been removed.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
it was done for side steps..
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 235 ![]() ![]() ![]() |
Appreciate the replies, I’ll see if I can find some form of clamp for the exhaust , were your steps fixed? SWMBO has hinted I should get some, our 2011 had deployable ones that worked! The D4 before that had fixed ones, I prefer the deployable ones but only when they work! 1972 Series 3 full of character
yes, fixed steps ... |
Keep an eye out on fleabay or marketplace for used deployable steps sets as they are often on there sir |
Would they be an easy fit? I guess I’d need the wiring loom for them to or is ‘everything’ there somewhere hidden up? 1972 Series 3 full of character
If yours had deployables fitted previously then there’s every chance the wiring is still there! Get underneath and see if there’s some unused big waterproof plugs loitering unused! If not either you had fixed fitted previously or the person who removed the steps,
Excellent tips thank you!
Don’t suppose anyone knows the fixing bolt sizes for a set of deployable steps?
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201 ![]() ![]() ![]() |
the problem is you need one 'magic' bolt for lh rear hinge. |
now I'm intrigued! tell me more about magic bolts!! 1972 Series 3 full of character
