Home > Maintenance & Mods (L322) > 2010-2012 front door bottom trim replacement
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
The trailing edge of the bottom seal on both of my front doors has bent out, approx 1". It looks like the rubber has split.
I believe the part number with the rubber seal is LR006222, however, I don't need the full trim part with seal, just the seal.
Has anyone found a suitable solution for this ? It's more a cosmetic thing than functional.
Post #719928 17th Jun 2025 12:16pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
My drivers side did this. A simple dab of Super Glue gel sorted it. Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719961 17th Jun 2025 9:13pm
JonnyCJ
Smashing - will give that a go, thanks.
Seems to be a common issue. Mind you I remember the original Superglue ad from the 70’s where a gymnast glued two ends of a thick rubber band together and then proceeded to jump on it stretched across the parallel bars.
Should hold my rubber door trim…
Post #719962 17th Jun 2025 9:31pm
rob8420
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Oh that’s a handy tip, passenger side door has done this on ours! 2011 FFRR Vogue SE Stornoway Grey
Post #720550 29th Jun 2025 1:44pm
