Home > Maintenance & Mods (L405) > Engine mount replacement
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I had a failed LH engine mount diagnosed today. The technician believes this is the cause of the driveline clunk I get under full throttle at slow speeds or after a downshift. The mount is torn and causes the engine to flex significantly.
I have the L405 service manual, except it does not include the SCV8 procedure. I believe the mounts are the same for all engines from 2013-2022 based on the part number. The service manual for the TDV8 shows a pipe going into the bottom of the mount which doesn’t appear in the two videos (petrol engines).
The YouTube video I have watched looks dead simple. He doesn’t remove the engine mount bracket. Instead he lifts the engine slightly to rotate the mount out. It isn’t English, but I think I got it.
I am going to do some digging to see if I can do it myself. The book time is 3-4 hours. $640+ CAD in labour could be better spent elsewhere.
Anyone else replace the engine mount themselves? Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #653904 18th Jan 2023 4:36pm
Bora20
My buddy and I tackled a few things tonight. After replacing the oil pressure sensor on his F150 Ecoboost, we moved onto the FFRR engine mounts. Simple re/re 🙂…it took us about three hours.
My LH mount was destroyed internally and I could spin it 360 degrees. The RH mount was intact, but worn.
Tools required:
- basic hand tools
- 2x 3/8” wobbles
- 1x female torx socket (forget the size)
- 1x 6” extension
- 1x 3’ extension
- 1x 4’ extension
- 1x 21mm crowfoot
Parts required:
- 2x LR033197 engine mount nut
- 8x LR033201 engine mount bolt
- 2x LR105970 engine mount
- 1x LR033655 steering column bolt
We put the FFRR in high suspension and drive it into four 6” ramps. Then removed the engine cover, air intake accordion pipes, side engine covers, tow hitch cover, engine skid plate, and transmission skid plate. Then we removed the steering column bolt, one-side engine mount nut, engine mount bolts, and the RH engine ground strap. The other engine mount nut was loosened with a little play. Jacked up the FFRR using the oil pan with a floor jack and three 2x4s.
The engine raised on the side without the bolt and tilted inward. We raised it slowly and checked often to allow the mount to be removed. A little twisting and the LH mount came out. The new mount fit in with the nut put back in loose. Then lowered the engine until the mount was seated and high enough to twist. We installed the four engine mount bolts hand tight, lowered engine fully, and torque the four bolts first using the torque pattern. The nut stayed loose. Then we moved to the other side and removed the nut. Repeated the above process, then lowered the engine. Torqued the engine mount nuts using the crowfoot, and reinstalled all other removed parts.
We made a test drive and waited for the engine to get to temperature. Once there, I floored it from a dead stop. Instantly it leaped forward. No more hard clunk!!!! It just hooks up and goes. No slop!!! It’s fixed!!!
$600 Canadian in parts/shipping. Free labour 🥰
Oh, and I need a new lower steering column as the boot gaiter is ripped 😭
Post #657832 26th Feb 2023 7:06am
Kot
Well done Thumbs Up Great write up 2018 SE SDV8 4.4 Byron Blue
Post #657833 26th Feb 2023 9:43am
Top job... Thumbs Up Bow down Pete
-Click here for Thread-
Post #657900 26th Feb 2023 8:33pm
knwatkins
Great news. Well done and thanks for writing up Thumbs Up Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #657902 26th Feb 2023 8:43pm
noone
United States
What mileage did you have when you replaced your engine mounts on your SCV8 5.0? 2023 L460 Range Rover SE P400
2019 L405 Range Rover ATB LWB
Post #720005 19th Jun 2025 2:34am
Bora20
Around 170,000 km. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #720024 19th Jun 2025 3:14pm
noone
United States
Thanks for the reply.
I’m right at 99k miles, and I have an abnormal resonance/vibration at dead on 1000 RPMs. Feels like I’m driving over cross hatched asphalt if that makes sense. It’s stronger under load driving, but I can also replicate the resonance while parked, stationary in Park or Neutral by holding 1000 RPMs. Wondering if this is transmission or engine. Intuitively, seems like maybe motor mounts, sure hope it’s only that and not tranny. Engine runs fine in all other rpm ranges. 2023 L460 Range Rover SE P400
Post #720025 19th Jun 2025 3:26pm
