Home > In Car Electronics (L322) > No sound from audio system.
Matt_71
Good morning, all,
I wonder if anyone can shed some light on this fault? I have a 2011 4.4 TDV8, it has been faultless since I bought it two years ago, however recently I lost DAB reception. I didn't think much of it to start with as reception is not great in my area. Since then I have lost the radio. I've tried the CD player, this says invalid format and the USB and AUX will not connect. I don't know if these are related, as I've only used DAB/radio in the past. I scanned the modules using an Icarsoft scanner, this comes up wit a code B1A06, which refers to a speaker/amp fault.
The system turns on and I can access the home screen.
Has anyone experienced a similar fault?
Thanks in advance.
Post #720045 20th Jun 2025 8:15am
check that battery and for moisture in the rear cubby.. Thumbs Up ... - .- -.
Post #720050 20th Jun 2025 9:49am
Matt_71
Hi Stan,
Battery is relatively new and I have no moisture in the boot.
Regards,
Post #720068 20th Jun 2025 11:16am
