Home > Maintenance & Mods (L405) > Car appears to be leaning to one side…????!?
Flyboy0902
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Hi all,
Following on from my previous post…, I’m still no closer to understanding why my L405 appears to be leaning to the right very slightly when viewed from behind…
The suspension looks perfectly fine..
I took it to a LR specialist who confirmed the distance between the centre of the wheel to the top of the wheel arch was approximately 1 cm less than it should be.. He then recalibrated the system.. When I got home, it had gone back to the way it was…?!?
Yesterday I changed the height sensor in that corner, which has made precisely no difference what so ever….
Had anyone got any other ideas of what this issue might be..?
Post #720346 25th Jun 2025 7:44am
fisha
Is it parked on perfectly flat ground ?
Slightly uneven ground at the front will have a big visual effect on how it sits at the back. V8 or else ...
Post #720383 25th Jun 2025 10:29pm
Flyboy0902
Yep. It’s perfectly level ground…
Post #720386 26th Jun 2025 7:34am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Mine (L322) did this, I became quite obsessive over it. For context the rear CVD shocks were Bilstein and brand new.
A full suspension recalibration via the GAP tool sorted it. My mechanics whizzy tool couldnt do it, or could but the process was too technical. With GAP it was easy, especially with two people. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #720394 26th Jun 2025 8:50am
Flyboy0902
My mechanic reset it originally using a gap tool. It went back to lop sided straight afterwards… I’m getting quite obsessive about it as well… Neutral
Post #720399 26th Jun 2025 9:54am
fisha
Off the top of my head, things that could make a car lean when parked up:
1 - Dampers stuck / stiff ... so its binding and preventing small, smooth suspension movement and so it gets stuck on a lean. Rare, but it happened to my active dampers on an old evoque. Could test by seeing if the car rocks smoothly when pushed side to side to make it lean back and forth. If its not smooth, or you hear dunts and little clunks as though friction is building up and releasing, then it could be that.
2 - The active cornering system (ACE) ... it uses hydraulics to push on the anti-roll bar links to counter leaning on cornering, so it easily has enough force to make the car lean if it wanted to. That said, when parked up at rest, the system should become unlocked and it doesn't place any force on the suspension. So unlikely to be this unless something is really wrong with it.
3 - The height sensors. Are they *all* fixed in position correctly ? Is the *any* looseness to any of the mounting points, the arms and the little ball joints. Even the slightest shoogle / play in these will create a variation in the height signal sent to the ECU. So you take it to the garage, reset it, all is well. Then drive it home, and the bumps of the road have moved the sensor / arm slightly from its reset position ... car tries to re-level, and its out of whack cause the sensor or arm is in a different position from before. V8 or else ...
Post #720436 26th Jun 2025 11:29pm
