|  | Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | I’ve just done the tensioner on the 405…..
|  2nd Feb 2025 4:21pm |
| Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301      | I noticed on line a couple of people saying they have alternator failure soon after doing the pulley / belt tensioner etc. but reading through all these, this does not get referenced. I am guessing it is not a definite that you need a new alternator when doing the tensioner job. Just some do if there has been a pull on the alternator due to failing tensioner? Has anyone who has changed the tensioner and left the alternator had plenty of happy motoring after without need to change alternator soon after?  Cheers, Ben. 2011 Range Rover Vogue 4.4 TDV8
|  14th Apr 2025 4:00pm |
| RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 93      | Are you guys changing the belt at the same time, or is that a more instruive job? Not sure if possible to get that in with the tight clearance | ||
|  24th Apr 2025 6:14pm |
| markh1 Member Since: 12 Dec 2024 Location: surrey Posts: 28    | I unfortunately have to replace my aux belt as it shat itself very soon after I changed the aircon compressor. Belt looked fine when I put the new compressor on so not sure what I did wrong.
|  26th Jun 2025 9:19pm |
| BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 52      | Hi Mark,
|  27th Jun 2025 5:50pm |
| Posting Rules
