Home > Maintenance & Mods (L322) > Brembo caliper bolts - any tips for removing?
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I've tried heat, penetrating oil and an air impact wrench...
Post #720569 30th Jun 2025 12:46pm
BAZ8046
Turn the wheel in and get a long breaker bar (at least 750mm) and scaffold tube if needed.
I always seem to get better results with a long bar when they are really tight. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #720570 30th Jun 2025 12:57pm
Bardley
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
...and I'll add my bullet point.
●Time
Penetrating oil over a good few days, and clean up as much around the Bolt head as possible to try and get the fluid in.
I've had weeks on some old bike parts, and eventually they loosened.
I suppose it depends on how soon the job needs doing? L405 2014 FFRR Autobiography
Corris Grey
Previously 2011 D4 SDV6 HSE Santorini
Post #720581 30th Jun 2025 5:01pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Try some Blaster 16-PB used it on some brake connectors that were rusted up and obviously delicate they released easily after two days soaking. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #720582 30th Jun 2025 5:11pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
https://www.screwfix.com/p/makita-dtw1002z...gLT9fD_BwE
I use one of these
Post #720586 30th Jun 2025 7:39pm
Gremlin500
BAZ8046 wrote:
Turn the wheel
This. It may not be obvious to the uninitiated, but better tool access makes a world of difference!
Great tip! Thumbs Up
EDIT: He means the Steering Wheel Rolling with laughter Rolling with laughter Rolling with laughter V6 Vogue - “Less is More” - less to go wrong!
Post #720591 30th Jun 2025 8:35pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
soaked with gt85(doesn't dry up as quick as wd40 i found) left for a day or so and breaker bar Thumbs Up
Post #720603 1st Jul 2025 5:54am
Rambles
I think the factory caliper bolts come with loctite applied….
So you may be fighting loctite rather than / in addition to rust and corrosion
Post #720674 2nd Jul 2025 9:12am
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
A retired mechanic neighbour swears by Plusgas as the best penetrant and it's all he uses now restoring old cars. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #720683 2nd Jul 2025 11:59am
krzysmaxi
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Maybe this will help someone:
Found online some time ago.
 _________________________________________________________________________
Krzys
Post #720749 3rd Jul 2025 1:24pm
Gremlin500
#2 for Plus Gas V6 Vogue - “Less is More” - less to go wrong!
Post #720751 3rd Jul 2025 3:04pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Another for Plusgas, I also love the Homebrew as detailed 50/50 Acetone/ATF.
When I had my 4.2 I had some real Squeaky bum time with the caliper bolts due to galvanic corrosion. I got them out using an Ingersoll Rand 2135 to tighten them, and then a 600mm breaker bar with a slow and steady pull. This seemed to get them moving. One of them when "loose" was still pretty rough, so I made one of the old bolts into a rudimentary tap by cutting a couple of flutes with a Dremel, and used that to clean the threads on the caliper. I used Molyslip Ceramic grease- yes i know this affects Torque settings, and I didn't find a "wet Torque" figure from Brembo, but I had the car 6 years and it was always fine. Formerly happymadison1978
Post #720834 4th Jul 2025 11:24pm
D3Jon
Liquid brake cleaner and diesel in a 50:50 mix works very well I've found.
Ironically, I also mix / keep it in an old Plus-Gas tin which stops the brake cleaner from evaporating Laughing
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #720860 5th Jul 2025 10:47am
