Home > Technical (L405) > Digital instrument panel stopped working (speedo etc)
Melvin
Hi all,
The main digital instrument panel on my MY18 L405 has just stopped working. When I turn the car on the only thing that comes on is the airbag warning light. Other than that it's completely blank. No speedo, or rev counter or anything at all on that screen. No other warning lights. The airbag light goes out after a while but then comes back on again.
I also just noticed that the tailgate intermittently fails to deploy when pressing the open button (key fob or on the car, doesn't matter). It does close via the button though.
Obviously the instrument panel is the main issue though but thought tailgate is probably related since it stopped working at the same time.
I've checked the fuse that controls the instrument panel (as per the handbook) and it is fine.
The car has been driven plenty recently without any problems so I don't think it's likely to be a battery issue.
The car has been sat in the sunshine in the recent hot weather so I suspect that is a likely catalyst for the problems.
Does anyone have any other thoughts on what to check, what the problem could be or experience with similar problems?
Many thanks,
Melvin
Post #720695 2nd Jul 2025 2:59pm
I know you think it's not the battery but checking the batteries is the best and cheapest way to start.
You probably have two and if one is failing all sorts can happen..
Check the voltage at the posts of each battery, you will need to remove the spare wheel to reach the main one and if you have a second you have to pull off the drivers side boot side panel..
Thumbs Up Pete
-Click here for Thread-
Post #720700 2nd Jul 2025 4:51pm
Melvin
Good point. Thanks for the suggestion, Haylands. I'll check them!
Post #720704 2nd Jul 2025 5:04pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Check your earth points too. They do funny things when they corrode
Post #720718 2nd Jul 2025 10:48pm
JLR stopped them in 15/16my Peter... Moved to a condenser arrangement... Thumbs Up
Post #720720 2nd Jul 2025 10:56pm
That makes life easier.... or do they fail as well...? Thumbs Up Bow down Thumbs Up Pete
Post #720725 3rd Jul 2025 12:20am
Kot
Well I have a second battery on MY 2018 2018 SE SDV8 4.4 Byron Blue
Post #720739 3rd Jul 2025 9:48am
Melvin
Hello,
I went out to try to do the battery testing this morning and the car is now completely dead. So, I think you were right that the batteries are not fully healthy!
I tried to charge the battery from the ports in the engine bay but both of my battery chargers were not able to do it. One just kept flicking on and off and the other one just came up with a "fault" light.
Is there a particular type of charger I need? Please see pics of my current chargers.
The blue charger managed to get enough juice into the battery to set off the alarm and make some clicking sounds in the engine but it would only remain "charging" for 5 seconds before clicking off. It would then try again with the same result.
There's not enough charge in the battery to open the boot so I'm not sure how best to proceed now!?
Thanks in advance for any advice.
Melvin
Post #720790 4th Jul 2025 12:12pm
kevinp
Try putting both chargers on at the same time. I did this once to overcome the resistance in the battery and then it carried on charging.
Post #720791 4th Jul 2025 12:16pm
Kot
Replace both batteries I bet they are original so 7 years is about right for a change 2018 SE SDV8 4.4 Byron Blue
Post #720805 4th Jul 2025 1:31pm
GraemeS
Australia
You might have to connect an extra battery to the car for the charger to see enough voltage to start charging, then disconnect the extra battery after a few minutes. L405 D350 SE Carpathian Grey D5 19" rims
Post #720829 4th Jul 2025 10:06pm
Melvin
Thanks for all the advice, everyone. Much appreciated.
I've bought two new batteries as Kot suggested.
However, I can still not actually get into the boot due to the lack of power. The doubled-up chargers didn't work, unfortunately.
When the new battery arrives would it be ok to connect it to the ports in the engine bay in order to provide the power to open the boot?
Or should I use the new battery in the way that GraemeS suggested and try to get the charger working to get enough power in the old battery to open the boot?
Or is there some other better way to proceed than this?
Thanks
Melvin
Post #720917 6th Jul 2025 2:59pm
Kot
Do you have a 2nd car and jump leads? connect with terminals under bonnet should easy be enough to open tailgate.
But I guess nothing will work if the earths are compromised under wheel arch! 2018 SE SDV8 4.4 Byron Blue
Post #720928 6th Jul 2025 5:42pm
Melvin
Yep, I've got another car and jump leads so I can do that. Do you think that that's a better option than connecting the new battery to the terminals under the bonnet?
I'll also take a look at the earths before I try it too. Thumbs Up
Thanks!
Post #720936 6th Jul 2025 6:33pm
Kot
I would do it first while you are waiting battery so you can open tailgate. 2018 SE SDV8 4.4 Byron Blue
Post #720966 7th Jul 2025 9:07am
