![]() | Home > Technical (L405) > Another sdv8 4.4 failed due to turbo |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
Engine failure due to a runaway engine running on its own oil is caused by a faulty turbo / turbo issue.
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 171 ![]() ![]() ![]() |
Yeah I’m starting to see a lot of sdv 8 going bad rather than the tdv8 but I’m guessing that’s due to no dpf???
For goodness sake be very, very, careful of some of the rebuilders - a friend had a V6 diesel go due to crankshaft failure - he went to a well advertised “rebuilders” in Lancashire they gave him a fixed price of £7k which was accepted.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770 ![]() ![]() |
Of no help to the op now, but I made a device for my 4.4 TDV8 to close the EGR butterfly for a while whenever the ignition was switched off so that switching off would kill a runaway caused by the primary turbo. L405 D350 SE Carpathian Grey D5 19" rims |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 204 ![]() ![]() ![]() |
Any diesel engined vehicle working in an oil refinery or a gas plant has to have a Chalwyn valve fitted to the air intake. This device is set to close and block the air if it reaches a flow rate greater than the normal full throttle value.
A rag stuffed in the air intake also works if you can get to it sharpish 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Slicing open the throttle body intake hose works if it can be done soon enough, or just squeezing the hose closed with multi-grips as I did to a TD5. L405 D350 SE Carpathian Grey D5 19" rims |
You guys have got me all nervous now..... |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
By the time you open the bonnet the damage is already done |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
You're going to need at least this!
Be very aware that a lot of bottom end parts for the 4.4 are not available and aftermarket are dubious to say the least. Feel for you, you are not alone facing this issue! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Would you be brave enough ![]() |
I expected as much ![]() I suppose you could do your bit for the environment by not creating all that smoke though.... |
Not necessarily, as mostly the damage is done when the sump runs out of oil. They will normally sit there and rev making lots of smoke and noise but choked to a degree by the excessive oil. L405 D350 SE Carpathian Grey D5 19" rims |
