Home > Maintenance & Mods (L322) > Dropped an EGR blanking plate in the engine - am I screwed?
steve2347
United Kingdom 2012 Range Rover Vogue 4.4 V8 Santorini Black
Hi guys
I've had the EGR soft deleted on my 2012 4.4 TDV8 and wanted to install a blanking plate as it was still open about 4% according to the GAP IID tool.
I managed to drop the plate and initially could just about see it resting on top of the EGR cooler engine coolant inlet hose, based on this image
I tried to fish it out using a magnetic rod but I believe it isn't magnetic as it is 304 stainless steel according to this
https://www.empiretuning.co.uk/product/egr...ver-sport/
It's now fallen further in and I can no longer see it, so presume it's further down. Based on this image, I suspect it is somewhere in the red circle
I'd like to know just how much of a problem I may have now caused myself?
I wanted to remove the inlet donut but I can't at the moment as there's a stuck bolt on the clip/bracket that's holding the EGR hose in that's starting to round. If I was able to get more access from removing it then I can take that route.
Otherwise, could I potentially leave it in there without any risk?
Post #720827 4th Jul 2025 6:42pm
GraemeS
Australia
The glow-plugs are down there but the wiring is covered so the plate shouldn't be able to cause a short circuit.
Are you using a 6-point socket for the bolt head? L405 D350 SE Carpathian Grey D5 19" rims
Post #720828 4th Jul 2025 9:56pm
steve2347
I am. I believe it should be the same size as the one that I used to loosen the bolts on the EGR outlet pipe where the blanking plate would be installed?
Now that's it's a bit darker out I was able to just about see it sat pretty much directly under the point where the EGR engine coolant inlet hose terminates. I tried to direct it out but it just moved it further underneath again.
My concern is that it's very likely to move if I drive the car so I would lose track of it. I would assume that there is also a risk of it coming out and then moving forward, which could then result in it ending up in one of the belts or the fan.
In terms of accessing that area, am I right in thinking that removing the inlet donut would be best? I'm hesitant because I don't want to disturb anything else and cause further issues if there is a simpler way to access that area
Post #720831 4th Jul 2025 10:19pm
steve2347
Ordered one of these inspection cameras with a hook attachment from Amazon for same day delivery.
https://www.amazon.co.uk/gp/aw/d/B0CZHT2VHS
After about an hour of the most intense game of hook a duck I've ever played, it's out!
Got quite lucky as it sat under right next to the bottom of the EGR cooler and there wasn't anywhere further for it to fall down. Dropped it a number of times, but eventually got it.
Post #720897 5th Jul 2025 9:56pm
Kot
Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #720902 5th Jul 2025 11:12pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
After all that, did you try installing it again??
Post #720905 6th Jul 2025 10:10am
steve2347
I did indeed, just with a bit more caution this time.
In case anyone reads this and has similarly little experience as me, then I recommend fully removing the left bolt and half undoing the right. That will give enough room to slide the plate in and you can hook it over the right bolt before putting the left bolt back once the plate is lined up. Really not a tricky job at all.
Definitely noticed a difference in the car with it installed. With just the soft delete it still felt improved, but really feels effortlessly powerful and much more responsive now.
Post #720906 6th Jul 2025 10:54am
