Home > Technical (L322) > 32003 3.0 Td6 Gearbox
Mark55t
My 3.0 Td6 has a reconditioned gearbox that's done around 30,000 miles.
After being parked overnight the drive seems somewhat slow to initially engage.....maybe 5-10 seconds. Fine after that for the rest of the day until the next overnight rest. The gearbox was serviced last week and no major problems were observed but the issue remains.
Any thoughts?
Cheers
Mark
Post #720890 5th Jul 2025 7:04pm
RRPhil
Transmission issues when cold, which disappear once warmed up, often relate to a low fluid level. Might be worth checking? You have the GM 5L40-E transmission, which uses Dexron fluid.
Phil
Post #720926 6th Jul 2025 5:01pm
Mark55t
Hi Phil
Thanks for your reply. I had hoped that the recent service would have cleared any fluid level issues but looking at the data sheet that you've attached I have my doubts as to whether or not the transmission specialist has followed the process quite to the letter.
I'll maybe try a drain and refill myself to be sure!
Thanks again.
Mark
Post #720950 6th Jul 2025 9:05pm
RRPhil
The most critical factor is that the engine must be ticking over while the level is set, otherwise the fluid in the torque converter drains down into the sump and produces an artificially high fluid level.
Phil
Post #720958 6th Jul 2025 11:13pm
Mark55t
Thanks Phil and noted.
Post #721134 10th Jul 2025 5:33pm
