![]() | Home > Technical (L405) > New engine require 4.4 sdv8 |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
Same block, the 448DT goes back to the L322, so any 448DT block can be a donor for a EU6 engine. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 171 ![]() ![]() ![]() |
Great stuff so is the engine the same as euro 5 and euro 6?? Just the adblu difference?? |
Pretty much yes, if you need a donor any 448DT will do, all the bottom end is identical.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
You will need the L405 sump pan,different to L322.
Great thanks guys. So now on the hunt for a block,get new pistons and bearings…not to sure about the repo crankshafts may have to find a good second hand original and then check the sizing. I believe the heads are good on mine just the sump blown and I can see marking on the walls of the pistons. |
I've got a spare 448DT block from my 2016 L405 if you're interested, probably best to take it out to first oversize if you want a 100% reliable engine as it had minimal wear and as I bought a complete shortblock assembly, I had a better option.
Nice that’s definitely a starting point getting the block. Sorry if I sound a bit thick but oversize it?? Where’s abouts are you mate? Yes I was looking at trying to get a complete block just ain’t seeing anything.
I'd suggest having a read through my earlier post here: -
Hi Mike thanks for your brilliant response been super busy at work and trying to find an engine. I might be able to get hold of a euro 5 engine which needs a bit of work but I think I asked earlier are the euro 5 and euro 6 the same as in the heads and injectors? As I mean what is the difference? |
My apologies for not replying earlier been crying in the corner looking at the car lol. Also have been stripping down my beast to get ready to pull it out. |
No problems whatsoever, we've all got lives away from our cars!
That’s what I thought but had to double check as all the head number matches up. Well I was looking at engine turns out it wasn’t fully functional. I’m still looking at getting another engine and seeing what comes up. |
Just try and get as much history as you can to back up it's a good one, when I tried asking questions about mileage and engine / vin numbers to trace service history the sellers went quiet on me or told a pack of lies.
Hi Mike well I’ve got an engine of 90k had a video of it running so it’s good got history of it as well. Question is my turbos are gone did you get yours done? |
