Home > Technical (L405) > All I want for Christmas..... is a new Engine
Page 7 of 7 <1234567
nike_bytom
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Hi all, quick update:
The engine strip-down is going well — slow, but making steady progress. I'm taking lots of notes and photos as I go. Just wanted to share the current state of it. Leaving it here đŸ˜„
https://www.youtube.com/shorts/6Ym3shEhBnk
Post #721266 14th Jul 2025 1:44pm
BAZ8046
Just for comparison this was my oil separator after 124k and before cleaning.
Mine might have missed one oil change early in its life as I have a gap in the records.
Has had 5k oil changes in recent times.
Looks quite different from yours!
 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #721316 15th Jul 2025 1:43pm
nike_bytom
Hi,
Quick update on the engine rebuild. I completed the engine disassembly today and removed the crankshaft to inspect the condition of the main bearings.
What I found is a bit puzzling. The conrod bearings are severely worn, as shown in the attached photos. Strangely, the front main bearing had been pushed out of place and was damaged. The surprising part is that the crankshaft journals are undamaged—almost a miracle. I measured the journals and they are within spec.
This raises the question: why was the front main bearing pushed out of place? Could it be due to a bent crankshaft?
I also discovered two broken piston oil jets and crushed tubes in the oil pan—another mystery.
Let’s continue the checks and hope the engine can still be repaired.
 L405 4.4 Vogue
L538 2.2 Prestige
Pozdrawiam
Rafal
Post #721899 26th Jul 2025 1:23pm
GraemeS
Australia
Check the front main journal for taper. L405 D350 SE Carpathian Grey D5 19" rims
Post #721900 26th Jul 2025 1:36pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I suspect the last person who was in there wasn't too good at rebuilding engines! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721901 26th Jul 2025 1:38pm
