![]() | Home > Technical (L405) > Electronic Parking Brake (EPB) Error on dash - Yet it works |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1433 ![]() ![]() |
I would start with fixing your MOT advisories, then ensure you have a code reader that can clear DTC's.
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247 ![]() ![]() ![]() |
So I purchased an Icarsoft to go deeper into the issue I am having with the EPB, where it works, yet I have the error on the dashboard (Park Brake Fault).
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 154 ![]() ![]() ![]() |
What is the code? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1877 ![]() ![]() |
There is a brake caliper assembly replacement routine on higher end diag equipment. Should be done when either caliper or motor are replaced |
It hasn't given a number, or I could see a number it just says State: Permanent Right actuator. Normally, you do see a code but nothing. Current Cars L405 Range Rover Vogue 4.4 Diesel Previous cars Lamborghini Gallardo 2006 Range Rover Vogue 4.2 V8 Supercharged Petrol 1996 Williams Clio 2 Aston Martin V8 Vantage Bentley GT Continental Porsche Cayenne 4.5s 4.2 V8 Supercharged Range Rover Porsche Boxster 3.2s Ford Kuga Nissan 350z BMW 316 Porsche Boxster 2.5s Golf 2.8 VR6 Highline Renault Clio 16v Vauxhall Nova GTE |
Is this a RR main dealer thing or something I can do myself? I had replaced this side before, and it worked for months, no issues, no error messages, but then something happened, I can't remember what, but I needed to replace it again, which I did. Maybe there is something else going on, but the main dealer isn't what I want to be doing, but I feel I am being pushed that way. It was a simple replacement project, 10 minutes, how hard can it be? It's just a motor swap-out. Maybe I will do the whole process again, strip it down, take it off, and replace it with another motor. Annoying thing is it all work,s just the dash has the warning on all the time. Current Cars L405 Range Rover Vogue 4.4 Diesel Previous cars Lamborghini Gallardo 2006 Range Rover Vogue 4.2 V8 Supercharged Petrol 1996 Williams Clio 2 Aston Martin V8 Vantage Bentley GT Continental Porsche Cayenne 4.5s 4.2 V8 Supercharged Range Rover Porsche Boxster 3.2s Ford Kuga Nissan 350z BMW 316 Porsche Boxster 2.5s Golf 2.8 VR6 Highline Renault Clio 16v Vauxhall Nova GTE |
After 9 months, it's finally fixed. I bought an Icarsoft V2.0, which has the service mode to recalibrate the EBP. Howeve,r I didn't know this function was there. I went into the usual ODB/Diagnostics functio,n tried to clear the codes it just kept looping round to clear but then would reappear instantly. I took the actuator off (again) and put the old one back on, hoping this would clear it or not make it worse.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
I don’t actually know if I was “ripped off” my indie said some related bits needed replacing so I told them to get on with it. I had no warning lights or smoke possibly because I never used the EPB just left the car in park. I do use it now (when I remember) and of course it works perfectly. Glad you got yours sorted, Geoff |
