Home > Technical (L405) > L405 GAP key programmjng
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi, first question on my new to me L405 !
I have read in places that the GAP IID BT can programme keys fobs on the L405 especially the earlier models ( mines a 2014 ) seems a lot of conflicting reports on this and wondering if anyone can confirm either way if it’s possible or not.
Post #721338 15th Jul 2025 5:43pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
It can, as long as the car hasn't had the security mod done. This mod locks access to the KVM through the OBD port. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #721378 16th Jul 2025 9:17am
tj196443
Thanks for that Zebedee, I couldn't see the menu on the Gap Tool but wasn’t sure where the menu is as I’ve only programmed L322 keys in the past and seemed to find the correct menu back then. Do you know which menu it is although I’m guessing it may be locked out as you say, the car is a 2013 and I was under the impression Landrover started locking them out after this model year.
Post #721386 16th Jul 2025 10:43am
Zebedee
When I tried it, Patrick from GAP said:
Its in Menu--Service Test--Remote Function Actuator
Battery replace is in the Gateway ECU, not the BCM
etc... this is all detailed in the user manual - https://www.gap-diagnostic.com/support/documents/IIDTool/
I had problems with this getting the report "Operation Failed" and "This version of Key Module May Need to be Unlocked Contact GAP", which then led to Patrick seaching the details of the car and then saying "Unfortunately your RFA was locked by LR thus keys cannot be added. Only solution is to replace the KVM".
This turned out not to be strictly true hence the post https://www.fullfatrr.com/forum/topic72989.html Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #721389 16th Jul 2025 11:26am
tj196443
Thanks Zebedee for the info that seems like a good place to start, I checked the manual and it made reference to having an already programmed key and sending the ecu info to GAP to allow the preparation of a file which has to be repeated twice, not sure what this means but I will try and follow the instructions in the manual.
Post #721392 16th Jul 2025 12:33pm
