Home > Maintenance & Mods (L405) > L405 Rear Centre Console Latch (Vogue SE)
Suki
United Kingdom 2017 Range Rover Vogue SE SDV8 Carpathian Grey
I'm posting this because there seems to be zero information about this anywhere - nada.
The problem I have (I can't believe I'm alone in this) is that the latch on the rear centre console's silver finish has peeled off. Anyone else had this happen?
Not a big deal, other than there's nothing out there that describes this issue and no instructions on how to replace the part. The part itself is easy to source - I got it from eBay for about £15.
The process to replace it is easy but not obvious. You fold the centre console down, and then you need to remove the insert that holds the cup holders. Before you do this, you need to remove the leather trim, just immediately forward of the cup holders - it just unclips. Then you can prise out the cup holder insert. When you look inside, you will see two screws that hold the latch. Simply unscrew the torx retaining screws and that's it.
Post #721307 15th Jul 2025 12:01pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Any pictures?
Post #721317 15th Jul 2025 2:05pm
Suki
I didn't take pictures of how it was done - it was really simple - but I did disassemble much of the console to work it out.
Post #721318 15th Jul 2025 2:08pm
DrF
I don't recognise that part, but I do have exec rear seats, so only 4 seat version with tables in the middle that's probably why?
Post #721320 15th Jul 2025 2:14pm
Suki
Yep - the 5 seat version has a centre armrest that pulls down as an armrest and for holding drinks.
Post #721321 15th Jul 2025 2:16pm
DrF
Makes sense, sounds like a good fix. Thumbs Up
Post #721322 15th Jul 2025 2:17pm
Abacus405
United Kingdom 2017 Range Rover Vogue SE TDV6 Carpathian Grey
Thanks for the write up. Mine has lost most of the silver and what’s left is quite sharp. I might pull mine off and 3d print it in black 2017 (67) Vogue SE Corinthian Grey
Post #721451 17th Jul 2025 1:08pm
Martin J
I have the same on my new to me 2017 model, have ordered a replacement from china, hopefully it isn’t too poor a quality. Thanks for the instructions for changing.
Post #721659 21st Jul 2025 11:44am
JamboM3
This has started to happen to my MY17, I thought this was previous owner abuse!
Thanks for the tip, I’ll get around to replacing it when it gets a little worse
Post #721696 21st Jul 2025 11:22pm
