L405 successfully adding a key using GAP IID 2014 MY | |
I have just successfully added a new key to my new to me L405 ( big thanks to Zebedee for pointing me in the right direction ) Seems to be a lot of confusion surrounding this for the pre locked OBD cars and I couldn't find a simple guide to help me on line.
The process basically involves updating your IID on the Gap website, doing a ECU flash and then sending ECU info to Gap, they then send you a message to update a ECU flash and Bobs your uncle you can programme a new key.
I was quoted £160 for a new key and have managed to do it with a replacement £15 key so very happy
When I get a bit of time I will write the process down so people can follow the procedure if that would help Forum members ?
A big thank you to Patrick at GAP for all the easy to follow instructions.
