Home > Technical (L405) > Instrument Cluster software upgrade through SDD
ss10
United States 2014 Range Rover Autobiography 5.0 SC V8 Fuji White
Anyone know if the cluster software can be upgraded using SDD?
I have a similar issue and prefer not to take the car to the dealer: Service Action N118: 'Service Required' Message Not Displayed & Service Reset Function Not Working
In my case the 'Service Required' message does show up intermittently and I am not able to perform the service interval reset. Tried using multiple scan tools as well as the brake + accelerator method.
Post #721623 20th Jul 2025 6:42pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Yes, I did my SDV8 instrument pack with SDD and the genuine JLR VCI, I wouldn't risk using a Mongoose clone to flash the cluster as its a big upload (too big for the GAP IID), and the Mongoose clones are known to occasionally fail with big loads. I'd also recommend a battery conditioner being connected to the vehicle as you'll see it drawing 40amps plus whilst doing the flash process. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721639 20th Jul 2025 10:07pm
ss10
Thank you. Do you recall which special function you used for it?
Post #721640 20th Jul 2025 10:31pm
4RRS
I think I selected IPMA (image processing module A and it found a newer version, I did mine to extend the diesel / oil dilution percentage value from 6% to 7%. If you go through the guided fault finding menu tree relating to instrument display as if you have a fault or issue it will get you to where you need to be. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721643 20th Jul 2025 10:38pm
