![]() | Home > Technical (L322) > Broken locking wheel nut key. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
This morning I attempted to adjust the handbrake on my FFRR, but was thwarted at the first stage.
Locking wheel studs should not be tightened up fully, only nipped up until they are secure |
Sadly the last person who had the wheels off was not aware, and probably over tightened it with his windy gun |
Not much help I know but I never use locking nuts they only give you untold grief like this case and if a thieving pikey has a jack capable of lifting a Range Rover high enough to nick your wheels then they are going to have the were with all to get a locking nut off . 2008 MY Supercharged
agreed, if it was not for the cost of a set of replacement tyres at over £1K, and the fact the wheels share the same stud pattern with some BMW's and VW's, I would probably replace them with normal nuts. |
This happened to me on my D3 but I damaged the lock nuts so bad I could'nt get them n off. However worse still I had just fitted stormer 20inch wheels which I didnt like so I had replaced with 19inch wheels to find out two of the wheels i couldnt get of because of the damn locknuts. So I drove about with two stormer 20s and 2 x 19s on the car feckin nightmare. Two options and this does work believe me. Remove all the other nuts and drive the car around in a circle slowly what should happen is the nut will crack and dont worry the wheel wont come off . Once you hear the crack you can eaily remove the nut. This is a method used by some landrover garages apparently to remove stubborn or damaged locknuts. Despite trying this on the second locknut I couldnt get it to budge so I brought is to a Quickfit and they burned it off with a torch without damaging wheel. Needless to say since then I take locknuts off and replace with normal ones. Hope that helps. |
That sounds like a sure way to oval the wheel nut holes to me ![]() ![]() Gone - Range Rover Supercharged 2006 ![]() |
Justin
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
You can get a socket set that will undo locking wheel nuts, they use pins and shape to the nut as required. Ring around a few garage one will have a set. 2004 black Vogue TD6 |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Gator sockets?
yep thats it, one of them. 2004 black Vogue TD6 |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
That tool won't help! They're a rubbish design and the problem isnt grip, it's the outer sheath spinning. They are a pig to get off from direct experience. See the below post and pic of my own nut that had to be attacked with a grinder, chisel and scaffolding bar!
It's booked in to be sorted this thursday, I will post back with an update when I get the car back. I'm seriously thinking about ditching the locking wheel nuts to avoid tis happening again. ![]() Gone - Range Rover Supercharged 2006 ![]() |
Paulo Member Since: 28 Sep 2010 Location: Glasgow Posts: 199 ![]() ![]() |
I'd ditch the Locking Wheel nuts too....
