Home > Maintenance & Mods (L405) > Offside Boot Trim Removal - the buttons part!
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Hi all, I am aware of how the main offside boot trim panel comes off to expose the secondary battery but I cannot see just how the part that holds the buttons comes off? Is this one as straight forward? Do the buttons have to be removed first?
Picture borrowed from another post!
 _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #721583 19th Jul 2025 5:50pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Take the black plastic trim off and it just pulls off
Post #721673 21st Jul 2025 6:51pm
GraemeS
Australia
How is the black plastic trim removed without damaging it please? L405 D350 SE Carpathian Grey D5 19" rims
Post #721690 21st Jul 2025 9:55pm
zenman63
It has two good clips, pull it out and it’s comes free, it’s also tucked under the boot rubber.
So pull it towards you, it has clips that slide under not poppers.
Post #721694 21st Jul 2025 11:16pm
GraemeS
Australia
Thanks. I had tried a couple of times but each time thought that clips were about to break. Mine's a MY21 but I'd be surprised that they've changed since the first L405. L405 D350 SE Carpathian Grey D5 19" rims
Post #721699 22nd Jul 2025 3:52am
ReggieMac
Do the buttons easily pop out? Is there a specific place to prise from i.e. from the bottom? The black bit looks quite fragile and I dont want to damage it? Actually to get the trim off do I even need to pop out the button first or can i just unplug it once ii have pulled the main trim off? _______________________________________________
Post #721705 22nd Jul 2025 9:58am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
There's enough slack on the switch loom to remove the trim and then disconnect, or if you want to remove it, i think each side at centre position is where to push in the metal retaining tangs L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #721710 22nd Jul 2025 11:49am
