Home > Maintenance & Mods (L322) > Powerloss and P0191-20 fault code 2004 L322 TD6
Microflex
Norway 2004 Range Rover Vogue Td6 Java Black
Hello,
I experienced a powerloss and engine failure the other day. The fault code i found was P0191-20 fuel rail pressure plausibility - regulator deviation. After a while the engine started again and i barely made it to a petrol station. I filled the tank fully and have not had a failure since.
I suspect a faluty fuel pump. The tank read 1/4 when this happened.
I have for a while now noticed a variation in idle rpm. And noticed that it is pulsating.
Am i right to assume a faulty fuel pump? Or is it something else?
Post #721714 22nd Jul 2025 11:36am
