![]() | Home > Technical (L322) > EAS fuses |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
The 20A is the main power supply to the EAS ecu, one 5A is the feed-back from the compressor relay so that the ecu knows that the relay contacts are closed and the other 5A is the ignition sense to know that the ignition is on. Removing the 20A fuse prevents the valves in the valve blocks from operating.
