Home > Maintenance & Mods (L405) > TYRE Pressure Monitoring System - FAULT ( TPMS )
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Guys can anyone sort this one out .............
so now 2 Months on
with either the
Range Rover re-calibrated ( Factory reset with Snap On Tool
OR
Reset with Land Rover dealership diagnostic tool
I get this fault:
The car runs perectly for around 50 to 200miles ( motorways & A roads ) with NO amber TPMS warning lights coming on.........
THEN for what ever reason the amber warning light comes on - fault ?
so stop the car
Snap on Tool comes out - into the `ECU port - FACTORY RESET EVERYTHNING - takes about 5 mins
Start the car and is all perfect again for around 50 to 200 miles
Then it starts all over again !
Now I have purchased all new parts for the TPMS as below:
1) Purchased Brand New TPM Senors x4 from LR dealeship
( £600 ish )
2 Purchased Brand New Landrover TPM reciever ( £ 150 ish )
3 Calibrated all 4 wheels / TPMS with Snap on Tool - all OK
4 Purchased another Brand New Range Rover car battery 900 amps - so voltages are spot on ( £ 380 ish )
5 all x4 tyres on Range Rover are brand new ( 3,000 miles so far )
Ranger Rover has been reset and all x4 TPMS codes have been entred - all correct
Tyres are at correct pressures
Tyres are correct ie `MINT condition with 7mm tread
Tres are at the corrcet Tyre Pressures - handbook checked
Is there such a thing as a " Ghost in the Machine "
I have even had the main battery disconnected for 2 days with the Earth Lead only attached
to ensure no static or current is left in any of the ECU's
Everything else on the L405 Range Rover is 100% perfect - ie NO other waring lights
It's just this TPMS cant seem to play ball
IT WORKS WHEN Reset FOR 100 or 200 miles - then all of suddend on the motorway travelling at 70mph it comes on - saying Fault ??
IT IS WORTH NOTING - There is NO spare in the boot
would appriciate help on this one.
Post #721760 23rd Jul 2025 10:43am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Might be a complete red herring but my TPMS went haywire after I fitted a dash cam. Disconnected the DC and the TPMS came back on. Now I keep the dash cam on and TPMS works sometimes. Seems I can have one or the other.
Good luck.
Post #721769 23rd Jul 2025 2:14pm
EmiratesA380
Spridget
Now thats an interesting comment !
something so simple as that -
out of interest we Dash cam we have are
Blackvue DR900S-2CH 4K Dashcam
I will disconnect from the Mother Board as road test
Thanks for taking the time to reply - appricated
Post #721772 23rd Jul 2025 3:22pm
EmiratesA380
HELP WANTED - TPMS
help .....
after everything been replaced with genuine lr parts from main dealer -
the tpms - works for around 100+ miles
after
when the amber warning light comes on & stays on - it's reset using the snap on tool to reset everything on the car -
after this it's perfect again - works ...... but only for 100+ miles or so ( today 175 miles )
example
with it fullly working - travelling down a motorway at a steady 70 mph - the amber warning tpms will light up saying .........fault.
any thoughts ?????????
car battery - is brand new
voltage is 13.2v parked
tmps all x4 are brand new
tpms codes for each wheel are spot on and shows on the snap on tool - correct
reciever mounted in headliner - is in the correct poition & plugged in ok
each wheel sensor behind the wheel arches are facing the correct way and slotted into lr holding brackets facing the wheel of travel - wires are al ok
Post #722164 1st Aug 2025 9:58am
Can you view each reader? There is a reader (Ariel looking thing) inside each wheel arch liner. Could one of these be faulty? As you’ve covered off most other things…
Post #722166 1st Aug 2025 10:15am
EmiratesA380
A few weeks ago whilst inspecting the landgear - I thought about this, I was checking the brake shoes and other bits
You may have a good point.
The 5.0L supercharger was purchased new - so I know its never had any knocks/damage - ie never been into a workshop
That said 6 months ago
I was cleaning up Drivers front wheel and deceided to take off the Drivers Wheel arch completely -
NOTICED that the Sensor Paddle ( which should be clipped into a holder and ensures the Senor Paddle faces forward looking at the tyre - WAS HANGING at a 45 degree angle down ?
How and why it was like that I still do not know !
The Senor Paddle was washed and rehung in the correct forwad facing position
COULD The other 3 Senor pads be like this ( oh a Big Thank You to a Factory guys ) - as I have never know anyone get their hands on these wheel arches.
Anyway when I am off for 3 weeks that a job to investigate the other 3 wheek arches
Appreciate your time Cam-Tech-Craig Thumbs Up
Post #722821 14th Aug 2025 10:04am
Your very welcome sir… Report back in due course with your findings 👍🙏
Post #722832 14th Aug 2025 12:25pm
EmiratesA380
your very welcome sir… report back in due course with your findings 👍🙏
Idea
update
a few weeks off work now and i started to really get to the bottom of this fault
using our snap-on tool
1) read any codes present
2) then ........... cleared any fault codes that came up
3) wait 30 minutes - all power off car - battery disconnected
4) using the snap on tool - complete re-set on all 39x ecu's
complete re-set tool - amazing piece of kit !
everything gets light up and down, seat belts chim, fuel lock clicks open & closes, doors lock & unlock etc etc etc......
5) with the car now completly re-set drive it for approx 10+ miles
at this point theres no amber warning lights for the tpms - its all 100 perfect !
but
6) as soon as it gets to
zero miles to 114.5 miles - amber warning lights back on - fault
after complete re-set
116.05 miles travelled - amber warning lights back on - fault
new after another complete re-set
119.10 miles travelled - amber warning lights back on - fault
so now we know its time related and not milage related
any thoughts ?
Post #724843 20th Sep 2025 1:47pm
GraemeS
Australia
What fault codes are recorded and have the possible causes for the codes been investigated? L405 D350 SE Carpathian Grey D5 19" rims
Post #724863 20th Sep 2025 9:42pm
EmiratesA380
GraemeS
Thank you Fella to write back on this one - NO FAULT CODES
Just says : FAULT
Post #725065 25th Sep 2025 9:52am
EmiratesA380
tyt.
update 25 september 2025
i have now got to the bottom of the tyre pressure monitoring system - fault
purchased brand new tpm senors x4 from lr dealeship
( £600 ish ) from graham
£155 or so on a x1 landrover tpm reciever ( above drivers head liner ) from graham
£300 or so on x4 senor paddles - located behind each weel arch - from graham
calibrated all 4 wheels / tpms with snap on tool - all ok
purchased another brand new range rover car battery 900 amps - so voltages are spot on ( £ 380 ish )
all x4 tyres on range rover are brand new ( 3,000 miles so far )
ranger rover has been reset and all x4 tpms codes have been entred - all correct
tyres are at correct pressures
tyres are correct ie `mint condition with 7mm tread
tyres are at the corrcet tyre pressures - handbook checked
___________________________________________________________________
now heres where we are at:
normal start - everything spot on - ie warning lights go out ( things are normal )
motorway travel - 70mph - varios speed betwen 60moh & 73mph
as soon as the trip meter gets to:
114.6 miles - then the tpms amber warning light comes on - fault
so stop the car
snap on tool comes out - into the `ecu port - factory reset everythning - takes about 5 mins
start the car and is all perfect again for around ???? miles
then it starts all over again !
122.3 miles - then the tpms amber warning light comes on - fault
so stop the car
112.2 miles - then the tpms amber warning light comes on - fault
so stop the car
119.6 miles - then the tpms amber warning light comes on - fault
so stop the car
i persionally think there a gremil in the ecu eystem
ghost in the machine
or
something need to be coded
.[/b]
Post #725067 25th Sep 2025 10:04am
GraemeS
Australia
I have no experience with the Snap-on diagnostic tool but I wonder if another brand of diagnostic tool such as an IIDtool might retrieve a specfic fault (DTC) code that would hopefully identify the particular fault.
Is the message occurring at a particular time interval rather than a distance? L405 D350 SE Carpathian Grey D5 19" rims
Post #725073 25th Sep 2025 12:41pm
