Home > General (L405) > Where do you put your key?
E500
GrumpyPenguin wrote:
Here's a novel idea - fit cars with a receptacle to store the key in when you are using the car. It could even have a second use such as starting and stopping the car - oh wait, we used to have them and IIRC they were called ignition switches.
Laughing
I seem to recall my M5 had a little slot to hold the (keyless) key... It usually stayed in my pocket, or went in the cup holders. Like it does in the Range Rover.
I'm usually too worried about leaving it in the car to tuck it away somewhere.
Post #703303 28th Oct 2024 7:12pm
Bill
Pocket , but watch out…. If you lock the car , presumably just press lock on the fob, will not activate the lock, but whilst in the car it disables the key.
The only way to reactivate the key is by using the second key.. or the app…. Except they disabled the app.
So the second key is a tough call if you left the second key at home & you are in the south of france.
Happened to me two weeks ago, fortunately at home. I assume I had pressed the lock key accidentally, anyway twas disabled. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #703335 29th Oct 2024 1:09am
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
I hang my keys on this hook that I bought from eBay! That way I’m not worried about it scratching the piano black finish around cup holders.
Post #703368 29th Oct 2024 12:56pm
it also depends what you have attached to your car key fob....
i only have my yale type door key on my fob so no problem for pocket insertion ... ... - .- -.
Post #703370 29th Oct 2024 2:04pm
Jordie Barrett's sock
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I like the little hook idea.
Still can't find the slot behind the cup holders.
Post #703420 30th Oct 2024 2:37pm
you wont have the 'slot' on your year... ... - .- -.
Post #703422 30th Oct 2024 2:46pm
Tend to keep mine in the cup holders. I’ve only got a door key and the fob on the ring so it will fit in the little space between the 2 if we have drinks. There is nothing that can't be fixed with a hammer😜😜
Post #703642 3rd Nov 2024 9:18am
Stuart-
Mine is in the cup holders too. Which isn't ideal if you have a couple of bottles of water there. I don't want it in my pocket as I disabled keyless so need to press the buttons.
I've bunged it in the door pocket occasionally, but then I forget. I walk in the house, don't lock it (I don't need to, as it's on an enclosed drive), and spend 30 minutes the next morning looking for my key.
No slot on mine either. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
2006 Bentley Flying Spur in silver
Post #703729 4th Nov 2024 2:43pm
Always in my pocket. No other keys with it, just the fob. Don't see the merit in having it loose in the car - in my pocket I've always got it, in the car its odds on I'll forget it when I get out. Mike - MPx
Post #703736 4th Nov 2024 3:43pm
Glad I haven't got a slot on mine, was getting quite fretful searching for it!
Guess I'll continue to chuck it in the cup holders then. It was in my pocket most of last week, which became an issue when the boss wanted to use the Rangey.
"It's in my jeans pocket" is apparently the incorrect answer.
Post #703895 6th Nov 2024 6:01pm
RG9731
Always goes in the drivers door handle, fits nice dosent rattle and you can use the cup holders as intended!
Post #720217 22nd Jun 2025 10:28pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Pocket. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #721811 24th Jul 2025 5:11pm
JamboM3
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Indus Silver
Pocket, less crap rattling around and I don’t have to remember it when I get in/out
Post #721824 24th Jul 2025 10:36pm
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
Great idea, you should patent it. A while back, my car was in a friend's garage for some work. He gave me a set of keys & told me to take the van. Got in & spent the next few minutes pressing every button I could see to get it started. Was about to give up & ask him Big Cry when I noticed that slot you were on about, key fitted, gave it a twist & it started. Genius. Never did mention it when returning Whistle
Post #721837 25th Jul 2025 9:59am
