Home > Technical (L322) > Engine System Fault
cgarside
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Engine System Fault
Started my 2008 3.6 TDV8 this morning and the message Engine System Fault came up on the dash.
Plugged in my IID tool and found the following engine fault message:
[img]https://www.fullfatrr.com/gallery/albums/userpics/15778/normal_IMG_4789.png[/
Can anyone point me in the right direction to fix the issue ?
Thanks in advance
Chris Garside 08 Range Rover TDV8 Vogue
Post #721812 24th Jul 2025 5:58pm
steve2347
United Kingdom 2012 Range Rover Vogue 4.4 V8 Santorini Black
If it's the P132B-22 code in the image in your gallery then this thread may provide some more info
https://www.fullfatrr.com/forum/post342470.html
Not something I'm personally familiar with but might be worth checking other posts on here
Post #721820 24th Jul 2025 8:40pm
Tiprat
On our RR 57plate 3.6, it turned out to be the two top hoses took us ages to find it,
Tiprat Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #721834 25th Jul 2025 9:29am
cgarside
Thanks for the replies.
I had a top hose fail last year and replaced both so I suspect it’s not the hoses, but I will check (be nice if this was the issue though) !
The code would imply a problem with the turbo actuator. If this is the case, I don’t believe the actuator can be changed, rather I need to replace the turbo/actuator unit. 08 Range Rover TDV8 Vogue
Post #721858 25th Jul 2025 2:52pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
There are a good few threads on here about the turbo actuator and how to check it and get it moving again, the R/H one is fairly easily accesible, I have yet to get to the L/H one, hidden above the propshaft and quite difficult to access.
Post #721873 25th Jul 2025 5:06pm
