Home > Maintenance & Mods (L322) > L322 Deployable Steps - The Wedge Key
GGDR
A TALE A LUCK WITH A FLOPPY STEP
So a while back, on my drive opened my door and I heard a sharp 'crack' from the deployable steps and found the driver's side would no longer retract. Floppy step is not a good look.
Peering into the mechanism it looked like this thing called a wedge key was missing. Looked around a lot and can't seem to buy one. Info about the wedge key, let alone a part number, is elusive at best. If you buy a new motor you won't get one I don't think. But the motor was whirring and it was a come back to later job.
Fast forward some months and I decided to clean my gravel. There were weeds despite the weed mat and so I decided with the dry weather to sieve all the dirt out to proper stop the weeds coming back.
Here's Operation Gravel Clean
(Floppy step showing it's shame right there. )
I got bags of dirt out, quite satisfying actually, it's a lovely wax-on, wax-off kinda job. You can see the clean gravel nearer the door and the dirty gravel at the bottom of the pic.
As I was sieving I see a glint. Was it a roman coin? No. Better; I realised my luck. The wedge key. Never left the driveway. I'd juts assumed it came off somewhere on the road.
Turns out the bolt snapped, leaving one end still in the steps and the other in the wedge key.
So for me a very satisfying and lucky fix costing £2 for a new stainless M6 bolt 20mm length
If you can't buy one (I couldn't find one) you can make one, ideally in stainless.
Here are the dims:
 Cheers, Greg
Post #721553 19th Jul 2025 8:48am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I'm about to fit some used steps to my car and will need to make sure I have the wedges I guess. Are they normally bolted to the motor hinge mechanism? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #721557 19th Jul 2025 10:40am
GGDR
Tom hi!
they bolt to the motor shaft.
if the steps came off a car with the motors on then the key should be there. Cheers, Greg
Post #721561 19th Jul 2025 11:19am
QBee
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
My late L322 has the steps fitted, but the previous owner thought they had been disabled.
Fuse 58 in the awkward glove box fuse box is present and correct, so any thoughts how they could have been disabled? The managing director, alias head chef, is only 5ft 4 and has requested I get them working. I assume there isn’t a switch somewhere I have not spotted?
Post #721879 25th Jul 2025 7:08pm
