![]() | Home > Maintenance & Mods (L322) > New high pressure fuel pump on the way |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 309 ![]() ![]() |
Will you be fitting it or a garage? If you, I would be interested in your take on it, thanks. 2012 Vogue TDV8 in Aintree green over sand |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 295 ![]() ![]() ![]() |
I'll get my local Indy to do it. Although it doesn't look a big job, high pressure fuel squirting all over the place if I disconnect the wrong pipe at the wrong time, means that I'd be happy to pay an expert.
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 200 ![]() ![]() ![]() |
What does it sound like and where under the bonnet is the noise most noticeable please? 2012 4.4 TDV8 Vogue Santorini black ivory leather |
It’s a sort of rattle - most noticeable inside the car in the first few mins of driving. I thought it was a dodgy alternator bearing, but the Indy said it’s definitely the high pressure pump.
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1351 ![]() ![]() ![]() |
My injection pump got really noisy so I put some good injector cleaner in the tank and it has been quiet ever since. Worth a go? |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 276 ![]() ![]() ![]() |
Out of interest what injector cleaner did you use? I am sceptical as to whether those things actually work? |
Millers Eco Max. Absolutly stinks, so wear gloves!! |
